Overhead console / dome light removal?
Old Nov 19, 2017 | 10:24 AM
nishibear's Avatar
nishibear
10th Gear
Default Overhead console / dome light removal?
I've searched the forums and most of the pictures and steps I see were from previous models.
1. Does the 4th gen have any screws that I have to remove prior to pulling the whole unit?
2. Is it like previous models that require a fair amount of force to pull the plastic clips free?
Thanks so much in advance!
Old May 14, 2018 | 01:28 PM
Scrutator's Avatar
Scrutator
I'm wanting to remove mine to find a place to tap off for power for a dash cam. Already broke a tiny tab off the so-called "Cover, Forward Recog" (86466-48042), so I'm ordering a new one for $60. I'm sure the dome-light assembly is several hundred dollars, so I don't want to take any chances with it.
Old May 14, 2018 | 08:51 PM
lexnewbi's Avatar
lexnewbi
Tap off the rear view mirror. I had gotten a
 “mirror-tap” cable “mirror-tap” cable
and looked for power and ground from the connector to the rear view mirror. You can find the connector under the plastic cover of the camera on the windshield.
Old Sep 22, 2022 | 11:43 AM
cdlwood's Avatar
cdlwood
2nd gear
I was hoping someone had actually successfully removed their overhead console so I'd know for sure where to pull harder. I've seen a few posts that show just pull on the front (end closest to the driver) until the tabs pop out, but I pull on the console pretty darn hard and it doesn't budge. If anyone has removed this overhead console in an RX350, mine is a 2018, and has any useful tips, please, I'd love to hear them before I end up breaking something... Thanks!
Old Sep 22, 2022 | 01:09 PM
Chiefsfan's Avatar
Chiefsfan
Would you NOT be happy with this?
Old Sep 22, 2022 | 04:44 PM
mak99's Avatar
mak99
I've removed my console/dome light assembly some time ago and it was a fairly straightforward process (but definitely take your time), referencing a video that I'll try to find. I did this when I installed a dashcam that looks like a factory option, per another thread here on the forum which I'll also dig up...
EDIT: Link to dashcam thread:
https://www.clublexus.com/forums/rx-...den-too-2.html
EDIT #2: Some videos here, though I thought I watched one that was a bit more comprehensive...
https://smile.amazon.com/2016-2022-F...18&sr=8-3&th=1
FWIW, I bought this dashcam last July and it's still working just fine.
Old Sep 23, 2022 | 05:04 AM
cdlwood's Avatar
cdlwood
2nd gear
Great info mak99! Thanks for this. I just wish I had seen this prior to purchasing my dash cam a few days ago. Not sure I can justify purchasing another camera right away so I'll probably just pull down the console (carefully) and splice into 12v on the connector. But...I have a feeling I may soon replace it with this camera before too long...I like how it's out of the way.
Old Sep 23, 2022 | 05:33 AM
golferjack's Avatar
golferjack
It is very easy. Look at this video from Fitmax, the camera I have. The video shows the whole process.
https://smile.amazon.com/dp/B07TRDDC...ix=dshcam&th=1
Old Sep 23, 2022 | 09:32 AM
mak99's Avatar
mak99
IIRC, the video I'm thinking of might have been a YouTube link from the install instructions in the box.
Personally, I'd much rather have this built-in style with easy-connector harness than an external one that you have to cut/splice into the factory wires to get power. Of course you can easily replace that external style dashcam should it ever go TU, so it does have that advantage.
I guess I should pop out my SD card to make sure my dashcam is still working! Out of sight, out of mind...
akkord
Mar 3, 2020 02:36 PM
arnieosp
NX - 1st Gen (2015-2021)
Jan 19, 2018 10:58 AM
MushiSushi
Mar 4, 2015 08:52 PM
UmattWayO
Oct 8, 2010 11:58 PM
denkigroov
RX - 3rd Gen (2010-2015)
Mar 1, 2010 08:10 PM
