Brake pad replacement
https://www.youtube.com/watch?v=-Y1U8Iw88iA
First: The video above does NOT work for the 4th gen RX's. Period. I even posted a comment on his video and he admitted this (the guy has a poor communication style if not bad information, sorry, it's true).
Second, my suspicion is that IF you follow the posted NX procedure where you jump the two pins in the DLC connector THEN perform the button trick it might work.
I wasted a ton of time trying to get that guy's trick to work. Then I wasted a ton of time trying to get the ridiculously hacky/ancient Techstream software working on a laptop with one of the horrendous clone cables......HUGE waste of time.
So, where does that leave someone?
Simple: 9V battery and some cables (if you have a cheap multimeter in your shop you can use those as very easy probes. It was ridiculously easy to use a 9V battery and a C-clamp. Literally apply power, watch to see if the piston is pushing out (it moves at a snail's pace with a 9 volt battery so no fear unless you are asleep that it will "pop a piston" out). If you have the probes applied correctly then let it rewind a bit, c-clamp until you feel pressure, rewind more. DONE. Took all of 2 minutes or less per side.
As for the guy in the video talking about "Mess up your calibration if you use the battery trick". NO. It's a 2 wire system on our cars. That means the ECU literally is "watching" for voltage drops as it sees resistance against the rotor. I had zero codes result from this and zero drama. It's a very simple system.
So in conclusion....get a 9V battery, change your rear brakes, stop removing the EPB assembly and buying overpriced o-rings, go drink a beer.
Last tip: Before you remove the caliper make sure you have the EPB motor's electrical connector unplugged (it prevents you from breaking the connector or wires). Easy. REALLY EASY!
Only concern with the battery method is frying something. Does anyone know what the motor rating is for voltage and current?
Once again, why do they make such easy repairs so complicated. First they take away the trans fluid dipstick, then they use oil filter canisters, now electronic parking brakes.
It absolutely works. I did it on both rear brakes on my 16 RX this weekend. Zero issues. No codes, no faults, EBP functions without issue at all. This is about the easiest method there is for this over engineered mess. Want more proof? Lexus sells the dealerships an SST (special service tool) that essentially does the exact same thing (uses the 12V car battery in the vehicle) to apply power the same exact way in the event you have a dead EPB controller/etc. They wouldn't offer that option if it was damaging.
I guess it was fortunate for me i didn't see his video before changing brake pads after all.. would have wasted an hour getting frustrated especially what he said towards the end, and i probably wouldn't have o-rings ready for the EPB.... im gonna edit the post saying it doesn't work for our cars.
i guess I'll try the 9v battery trick again next time with better connectors
His name is Viktor G
the also said the rear brakes pads are showing signs of wear and probably should be done in the September service and quoted $700. It’s been a while since if got brakes replaced, but that sound really excessive. Is that how much the service is supposed to cost????
We got our 2017 Rx350 n early 2018 and got the 7 year 180k km extended warranty. Anyone know if I got th ca serviced elsewhere if the warranty is still valid???
it just seems excessive maintenance cost compared only no cost maintenance for my BMW M3. $350 for basically an oil change, tire rotation and preventive inspection for the 65k km service, plus and additional $190 for an alignment and $50 for resetting the TPMS sensor for swapping my winter tires with the regular that are already on rims (when regular swap is supposed to be included in the service in lieu of rotation).
anyway been feeling a little bit of price gouged at the dealer, wanted to get advice on cost of the quoted brake replacement cost and whether the extended warranty would be at risk if I got the car serviced elsewhere.
Did they show you a print out with the wheels out of spec or did they just recommend it?
I haven’t done an alignment in maybe 15 years and all my cars had even tire wear and always tracked straight.
Do you guys slam into curbs while parking at the mall on the weekends?
