Battery Issues
Old Mar 20, 2017 | 03:22 PM
kitlz's Avatar
kitlz
No, I don't play soccer!
Originally Posted by ggebhardt
then you need to get another dashcam. Like I said I have left mine running for several days along with the radar/laser detection system and it started right up.
A better solution would be to install an external battery for the dash cam. Mine is plugged into the cargo area power outlet to charge while driving, then it provides power to the dash cam when parked.The 12V battery isn't affected since the power outlets only work when the RX is turned on. The particular dash cam I have displays the voltage in the videos. It's 14.4 when driving and 12.6 while parked.
Old Mar 20, 2017 | 03:26 PM
tomtom74's Avatar
tomtom74
No, I don't. My dash cam is perfectly fine. Good for you!
Old Feb 1, 2018 | 06:26 PM
Marqevans's Avatar
Marqevans
Where is your camera mounted and how does the cord reach to the cargo outlet?
Old Feb 1, 2018 | 07:03 PM
mssca's Avatar
mssca
OP,
Do you have the official Lexus dashcam? I have the Lexus OEM dash camera. Not sure if this is only available in Canada and Japan. You may want to look into this because the quality is quite good and Lexus gives you a warranty on electronics.
Old Feb 2, 2018 | 03:03 AM
kitlz's Avatar
kitlz
Pictures are here. The Cellink battery came with a power cord but it had to be extended.
Old Feb 2, 2018 | 11:39 AM
Supranut's Avatar
Supranut
I know this is an old post but, I have the Thinkware F800 pro direct wired to the fuse panel with no backup battery, it runs all weekend long in parking mode and I have it set up to shut down at 11.6 volts and it’s never stopped recording. Also the battery hasn’t ever died with this set up. My 2007 Tundra still has the original battery in from the factory, only reason I swapped it out this year is because it makes me nervous going through another winter with a 10 year old battery, especially how cold it’s been here in northern Ohio .
I would definitely have have the battery tested. Automotive batteries are not designed to have a long constant drain to the point of complete discharge on them like deep cycle batteries. Automotive batteries are designed for high amperage at short bursts and they don’t last very long if they are constantly drained down to nothing.
Old Feb 4, 2018 | 03:08 PM
Jagnut's Avatar
Jagnut
I got the Lexus OEM dashcam installed by the dealer a few weeks ago and although it has a parking mode, I've never encountered battery problems.
Old Feb 4, 2018 | 03:11 PM
Jagnut's Avatar
Jagnut
Here it is
Old Feb 4, 2018 | 03:13 PM
Jagnut's Avatar
Jagnut
Here are the pics, sorry about the above post
Old Feb 5, 2018 | 09:40 AM
SirKong's Avatar
SirKong
Originally Posted by mssca
OP,
Not the official one. It's a Lukas dash cam. They did not have the official one at the time of purchase. I have stopped using the parking mode since and have not had the issue again.
Wilbick
RX - 1st Gen (1999-2003)
Oct 27, 2015 08:15 PM
semar
Oct 6, 2015 08:16 AM
Tact
GX - 1st Gen (2003-2009)
Jan 20, 2015 07:39 AM
cgawelko
12
Apr 17, 2014 12:47 AM
AlexusAnja
Sep 25, 2011 05:47 AM
