Hesitation problem at various speeds (TSB info post #159)
Old Sep 18, 2019 | 04:42 PM
  #1291
xxx350L's Avatar
xxx350L
Originally Posted by PWMDMD
It's hard to issue a recall on the ECM for a problem that may affect a tiny % of cars - quite possibly a problem so small Lexus hasn't even defined it as a problem at this point. It's also a stretch to say the unintended acceleration problem in 2009 was caused by the same problem. You are clearly emotional about this and you should be - what you described sounds scary. I think you're options are to report it to Lexus and try and help them find/identify the problem (could be something as simple as a randomly malfunctioning computer that is easily replaced and not a systemic problem affecting many cars) or getting rid of it. No one will know until Lexus investigates and no I'm not convinced a single report is going to mobilize Lexus engineering to descend on your dealership for emergency diagnostics and testing but it starts with reporting it Lexus.
The first incident of this problem was reported to Lexus, by me in person, on August 8, 2019. They did not try to replicate, and proceeded to address the hesitation issue with a computer re-flash. No change. I’ll be talking to Lexus again soon. Thank you for your response.
Old Sep 19, 2019 | 03:27 PM
  #1292
Eric0201's Avatar
Eric0201
I did the TSB today in Canada. I will try to see is there any difference.
I also notice if I switch from drive to reverse and I hold the break, I can hear a noice. If I do not hold the break, I cannot. I am not sure if it relates to transmission or break.
Is there any one has this issue?
BTW, I also replace my drive side outside mirror because I can notice some vibration when speed reach 110km/h or the road is too bad. Still notice the vibration on bad road and I will check in highway later.
Old Sep 20, 2019 | 09:53 AM
  #1293
GRJFER's Avatar
GRJFER
Not sure where you are located, but I would also report it to https://www.nhtsa.gov/
Old Sep 20, 2019 | 07:02 PM
  #1294
xxx350L's Avatar
xxx350L
After the first acceleration incident in August, I did report to NHTSA and, you’re correct, it only about 5 to 10 minutes. After this trip I will give them a call to update my case.
Old Sep 28, 2019 | 12:18 PM
  #1295
Aeon's Avatar
Aeon
Attached is the 9/26/19 revised/updated TSB. Don't know if it contains actual ECU remapping optimizations based on feedback or just updated coverage information. Print this out and give it to your service advisor. Mine claimed there were no "recalls" and the master technician had to inform him the TSB are different from recalls.
I had the TSB done and oh boy the normal mode now drives like sport mode. It's amazing. The gears are shifting so smoothly. I don't think it's placebo either because with the loaner NX300 I was given I thought to myself "this is how gears should shift."
And remember to take a ton of photos before sending your car away. I was too trusting thinking these guys deal with Lexuses everyday and that they must be super careful but nope. There's now a 2 inch scratch on my rear bumper, deep enough that I can see the dark plastic. The SA said he'll forward the issue to the customer relations and the service manager and I'll hear back by Monday or Tuesday since they don't work weekends. The funny thing is I have a $600 dual channel dashcam with $400 in backup batteries but I disconnected it to be nice and to give them privacy while they worked. I'm a goddamn moron.
File Type: pdf
Old Sep 28, 2019 | 02:43 PM
  #1296
xxx350L's Avatar
xxx350L
Thank you for the TSB update info. Sorry that your car was damaged. Stand firm and have them make it new again. No touch up paint or spot paint. Have them remove the rear facia and paint/clear coat edge to edge.
Old Sep 28, 2019 | 03:06 PM
  #1297
GSFRX350's Avatar
GSFRX350
Unbelievable!!!
What's this, the 3rd attempt to rewrite the software.
I try to be positive with Lexus but really, what the hell are they doing. And this TSB is a Revision so likely that anyone requesting it will end up with the original. Why not give it a new number?
Old Sep 28, 2019 | 07:22 PM
  #1298
DMPesso's Avatar
DMPesso
I think some wording has changed or maybe they added more models so it actually works for the 2019 since the original seemed to do nothing. I just checked the info for mine which is a 2017 F Sport AWD and the before and after info including the calibration ID is all the same as the original TSB. Did you do the original 0032-19 before this update or is this the first time?
Old Sep 28, 2019 | 10:44 PM
  #1299
gnguyen's Avatar
gnguyen
I had the TSB done last week. The service rep told me the only difference between this and the one in 2017 is a new shift point. My RPM how hovers at 1750 RPM in normal mode. This is above the crazy drone that occurs at 1500 RPM. The car is more drivable now. They also replaced the engine mounts with the latest softer ones, due to my complaint about excessive vibration, but didn't help. I told them ahead of time that they need to fix the alignment after the mounts are replaced. Well they didn't and I had to take the car back again; after the realignment, it's not as perfect as it used to be. This is so annoying. I also got a small ding on the rear fender that I found out last night. Dealers are quite something.
Old Sep 30, 2019 | 06:39 AM
  #1300
johnhey's Avatar
johnhey
I have done the same update couple of weeks ago with terrible result.
Now car changes gear too soon and end up to jerk feeling %50 of time when changes the gear. my smooth Lexus turned into a rocking chair now. BE AWARE
it happens more in down shift if you decelerate fast and sometime in accelerate there is a surge. (do you have this issue after TSB done? (L-SB-0032-19)
I went back to dealer and asked to put original ECU software (revert the TSB) but they say they can not go back and downgrade the software. Do you know if this is true?
My Car is 2019 non f-sport
Old Sep 30, 2019 | 07:20 AM
  #1301
Eric0201's Avatar
Eric0201
My dealer also said they cannot downgrade the software too.
Old Oct 1, 2019 | 07:30 AM
  #1302
bobett's Avatar
bobett
I had this done (2017 RX350) and it vastly improved the shifting. Felt like it should
Bob
Old Oct 1, 2019 | 07:38 AM
  #1303
rxtimes2's Avatar
rxtimes2
I also had the TSB done on ny 2017RX, and it improved the shifting significantly.
Old Oct 1, 2019 | 07:44 AM
  #1304
Aeon's Avatar
Aeon
I received a 4~5 mpg boost as well. Remember to reset your mpg meter and report back results!
Old Oct 1, 2019 | 09:44 AM
  #1305
mrmonster's Avatar
mrmonster
How long does the update take? Wondering if I can wait while they do it or do I have to get a loaner.
