Buzzing noise when engine is off
Old Jan 13, 2019 | 01:33 PM
  #31
yardie876's Avatar
yardie876
Originally Posted by LillyBelle
Thank you so much! I did search the forum, but didn't see these posts. Greatly appreciate the insight. I KNEW that one of the experts here could help.
Far from an expert. Just been around the forum for a while lol. Enjoy your new 450h.
Old Jul 8, 2019 | 07:41 AM
  #32
TLKBTK1027's Avatar
TLKBTK1027
Default Rear hydraulic sound and air conditioner noise
Yardie876, since you've been around a while, what do you know about a hydraulic sound in the rear of the 2016 RX after I turn it off? Had a GX for many years and never heard a sound like this. My guess is that it is some kind of leveling option but can't find anything in manual about it. Also, I did read several, many actually, complaints about the noise the air conditioner makes, haven't read if there is a fix though, do you know if there is?
Old Jul 8, 2019 | 07:50 AM
  #33
PeeVee's Avatar
PeeVee
For the air conditioning, yes there is a fix. Point no 3 at the link below:
https://www.clublexus.com/forums/rx-...ems-guide.html
Hydraulic sound? I know of a sound for the gas pump test when the vehicle is turned off, and it is noisy but normal. Can't remember where I read it.
Old Jul 8, 2019 | 11:10 AM
  #34
TLKBTK1027's Avatar
TLKBTK1027
Thank you!!
Old Dec 14, 2020 | 04:17 PM
  #35
Nauticalx's Avatar
Nauticalx
Default Pump noise after parking vehicle
Have a 450h. Not long after parking the vehicle, there's a pump or actuator of some sort under the hood that comes on for a few seconds then turns off. Comes on maybe 15 or 30 seconds after parking and sounds for only a few seconds. What is that thing?
Old Dec 14, 2020 | 05:05 PM
  #36
eddie420's Avatar
eddie420
From the owner's manual:
Old Mar 1, 2022 | 03:56 PM
  #37
PhxBill's Avatar
PhxBill
Default Electric motor running after car parked
At least twice, several hours after the vehicle was parked, turned off and locked, I have heard a small electric motor running in the lower rear of my 2021 base model. Sounded like a small electric air pump. Didn’t run very long, and it started well after the vehicle was parked. What could this be?
Old Mar 2, 2022 | 05:25 AM
  #38
777rx400h's Avatar
777rx400h
see previous post
Old Mar 2, 2022 | 05:26 AM
  #39
ravenuer's Avatar
ravenuer
I'd say your answer is in the post immediately before yours.
Old Mar 2, 2022 | 07:15 AM
  #40
PhxBill's Avatar
PhxBill
The mods merged my original fresh post into an existing thread, so yes now the answer is obviously there….
anyhow, thanks to those who answered this question long before I posted.
Old Jan 16, 2023 | 04:17 PM
  #41
lenbabin's Avatar
lenbabin
Default Motor Humming
The other night I went into my garage and heard this low frequency humming as though a small motor were running. I looked all over the garage for a source and found nothing. I am butted up against a neighbour, and I even stuck my ear to the common wall to see if I could hear anything. Nothing. I could not identify a sound coming from the RX but I thought that this was the last candidate, so I got my key, started it up, shut it down, and - presto - no more sound. Huh? Called the dealer and he had no answers. He said that I would have to bring it in and let it sit and they would check it after hours when all was quiet at the shop to see if they could identify anything. Huh? I have owned this car for 8 months and have never noticed this. Anyone know about this? Quite mysterious.
Old Jan 17, 2023 | 06:53 AM
  #42
jollick's Avatar
jollick
It was most likely the gasoline evaporation system, or something like that, not sure of the technical term. I hear it occasionally when my RX450h is parked. This is normal.
Old Jan 17, 2023 | 02:06 PM
  #43
bamalam's Avatar
bamalam
Check your owner's manual and/or see post #36, above. The sound you hear is normal. On a related note, I wonder if dealer reps get special training in Groundhog Day-style forgetfulness?
Old Jan 23, 2023 | 12:07 PM
  #44
lenbabin's Avatar
lenbabin
Car had been sitting for a couple of hours. Just happened to go into the garage for something else and heard it. It continued for a couple of minutes while I hunted for the source. Once I started it and turned it off, it went away.
Old Jan 22, 2024 | 06:17 AM
  #45
Lexus4rx's Avatar
Lexus4rx
Default RX 350 fuel pump buzz noise
Is it normal to be experience this same issue (see thread below) with 4th gen RX 350
https://www.clublexus.com/forums/is-...uzz-noise.html
After about 15 minutes, the sound goes quieter and goes away.
I'm aware that there is a recall on fuel pump, and just wanted to check. I've never heard this noise before in my 4 years of owning this vehicle.
