Cargo Area Lighting
Old Oct 4, 2021 | 12:12 AM
  #91
Amazon Amazon
This is a 6000K bulb meaning it is white leaning towards blue.
If you want warm white
Amazon Amazon
I have these build quality is questionable the leads are usually not bent right. But they give off warm white almost exactly like the original bulb and are a fair bit brighter.
Old Oct 4, 2021 | 08:40 AM
  #92
thug9030's Avatar
thug9030
Originally Posted by LeX2K
https://www.amazon.com/dp/B08VS52KCG
https://www.amazon.com/dp/B07ZK7DFCZ
thank you and is our bulb # 194 or 168
Old Oct 9, 2021 | 04:10 PM
  #93
n0v8or's Avatar
n0v8or
For those whose vehicles have the dim factory LED cargo lamp assemblies shown in the first post of this thread, here is an inexpensive way to upgrade them to ~10 times the brightness:
https://www.clublexus.com/forums/nx-...-lighting.html
Old Jan 26, 2023 | 09:24 AM
  #94
Chiefsfan's Avatar
Chiefsfan
Default Various LEDs in the car.
Has anyone replaced the "LEDs" in the cargo area with brighter ones? Are these LEDs that are already installed really bulbs as we know them or is it something else? If they cant be changed,obviously I wont mess with it, same goes for the back up lights I guess or any other LED in there. Mine is a 2022 and came with LEDs. The reason I ask to is it says if you have LEDs and wanna change them take it to a dealer. Why take it there?
Old Jan 26, 2023 | 09:28 AM
  #95
ravenuer's Avatar
ravenuer
Why take it there???? lol $$$$$$$$
Old Jan 26, 2023 | 06:39 PM
  #96
nitalice's Avatar
nitalice
Originally Posted by Chiefsfan;[url=tel:11437096
11437096[/url]]Has anyone replaced the "LEDs" in the cargo area with brighter ones? Are these LEDs that are already installed really bulbs as we know them or is it something else? If they cant be changed,obviously I wont mess with it, same goes for the back up lights I guess or any other LED in there. Mine is a 2022 and came with LEDs. The reason I ask to is it says if you have LEDs and wanna change them take it to a dealer. Why take it there?
I used this
https://www.amazon.com/iJDMTOY-Bright-Assembly-Compatible-Powered/dp/B099J3XKZQ/ref=mp_s_a_1_1?crid=7FSCSZAQDF7N&keywords=iJDMTOY+Super+Bright+2W+High+Power+Xenon+White+Full+LED+Trunk+Cargo+Area+Light+Assembly+Compatible+With+Lexus%2C+Compatible+With+Toyota&qid=1674786864&sprefix=ijdmtoy+super+bright+2w+high+power+xenon+white+full+led+trunk+cargo+area+light+assembly+compatible+with+lexus%2C+compatible+with+toyota%2Caps%2C114&sr=8-1 https://www.amazon.com/iJDMTOY-Bright-Assembly-Compatible-Powered/dp/B099J3XKZQ/ref=mp_s_a_1_1?crid=7FSCSZAQDF7N&keywords=iJDMTOY+Super+Bright+2W+High+Power+Xenon+White+Full+LED+Trunk+Cargo+Area+Light+Assembly+Compatible+With+Lexus%2C+Compatible+With+Toyota&qid=1674786864&sprefix=ijdmtoy+super+bright+2w+high+power+xenon+white+full+led+trunk+cargo+area+light+assembly+compatible+with+lexus%2C+compatible+with+toyota%2Caps%2C114&sr=8-1
for my 2021 replacement for all 3 led
Old Jan 27, 2023 | 05:28 AM
  #97
IntrinoX's Avatar
IntrinoX
Just put these in! What a night and day difference!
Old Jan 27, 2023 | 02:33 PM
  #98
Chiefsfan's Avatar
Chiefsfan
Originally Posted by nitalice
I used this https://www.amazon.com/iJDMTOY-Brigh...s%2C114&sr=8-1 for my 2021 replacement for all 3 led
Thanks... I think I broke part of my lens off in taking it out. I could superglue the part back once I find the right bulb(LED) I want but this may solve my problem, just get 3 of these... Did you by chance swap your back up bulbs out and if so what is already back there for a 2021/2022?
Old Jan 27, 2023 | 03:00 PM
  #99
nitalice's Avatar
nitalice
Originally Posted by Chiefsfan;[url=tel:11438030
11438030[/url]]Thanks... I think I broke part of my lens off in taking it out. I could superglue the part back once I find the right bulb(LED) I want but this may solve my problem, just get 3 of these... Did you by chance swap your back up bulbs out and if so what is already back there for a 2021/2022?
I did not replace my back up bulbs since it seemed to be bright enough for me. But I did replace for my 2019 sienna because Sienna bulbs were halogen and so dim. So I used this
JDM ASTAR Extremely Bright 2000 Lumens 360-Degree Shine 921 912 90-EX Chipsets LED Bulbs For Backup JDM ASTAR Extremely Bright 2000 Lumens 360-Degree Shine 921 912 90-EX Chipsets LED Bulbs For Backup
which did really help improve the vision at night time. I think it would fit with RX as well.
Old Jan 27, 2023 | 03:06 PM
  #100
Chiefsfan's Avatar
Chiefsfan
I did not replace my back up bulbs since it seemed to be bright enough for me. But I did replace for my 2019 sienna because Sienna bulbs were halogen and so dim. So I used this JDM ASTAR Extremely Bright 2000 Lumens 360-Degree Shine 921 912 90-EX Chipsets LED Bulbs For Backup which did really help improve the vision at night time. I think it would fit with RX as well.
OK.. Ive changed many bulbs before on my Highlander, even the headlights... Im not even sure what bulb size even goes in my 2022 RX ..Is it more of a traditional bulb replacement wedge type?
Old Jan 27, 2023 | 03:38 PM
  #101
nitalice's Avatar
nitalice
Originally Posted by Chiefsfan;[url=tel:11438052
11438052[/url]]OK.. Ive changed many bulbs before on my Highlander, even the headlights... Im not even sure what bulb size even goes in my 2022 RX ..Is it more of a traditional bulb replacement wedge type?
This is from the manual
Old Jan 28, 2023 | 08:32 AM
  #102
Chiefsfan's Avatar
Chiefsfan
I understand that, since I dont have single beam I have something else, it does not say what it is.
Old Jan 30, 2023 | 06:27 AM
  #103
autotech13's Avatar
autotech13
Then you must have the triple beam headlights!
Old Jan 30, 2023 | 02:19 PM
  #104
Chiefsfan's Avatar
Chiefsfan
I do..... Ive changed the cargo and door lights, justbtrying how to find out what the backup light assembly looks like
Old Feb 11, 2023 | 01:45 PM
  #105
MP692's Avatar
MP692
10th Gear
I added these on a touch dimmer. No more lighting issues!
