Transmission Issue RX
Old Jun 27, 2025 | 11:23 AM
turyus's Avatar
turyus
2nd gear
Default Transmission Issue RX
Hi everyone,
I have a 2020 RX with around 90,000 km on it. Occasionally, when I first start the vehicle, the transmission doesn’t shift gears properly. For example, while merging onto the main road, even when I reach speeds around 60 km/h, the RPM keeps climbing up to 4,000 without upshifting.
If I try to shift manually, the display shows that it has shifted, but the RPM doesn’t drop, and the car stays in the same gear. When I pull over, turn the engine off, and restart the vehicle, everything goes back to normal.
Additionally, when I first start the car, sometimes moving the gear selector into D or R feels very stiff, and the transmission doesn’t engage smoothl it feels like it’s stuck.
Has anyone experienced a similar issue or have any idea what could be causing this? Any advice or recommendations would be appreciated.
Old Jun 27, 2025 | 11:42 AM
GS4_Fiend's Avatar
GS4_Fiend
Allow the vehicle to warmup a little longer and see if it improves?
Lastly, are you the original owner? If not, perhaps someone installed aftermarket ATF?
Old Jun 27, 2025 | 12:14 PM
turyus's Avatar
turyus
2nd gear
The car just reached 90,000 km, which is considered major maintenance. I had the transmission fluid changed at the authorized service. I’m not the first owner of the vehicle; I bought it around 70,000 km. In the beginning, I didn’t have any issues, but the problem has started to appear recently.
Old Jun 27, 2025 | 09:24 PM
bucfan22's Avatar
bucfan22
if you just have transmission oil change, more likely they didn"t do it correctly. Years ago i have my es350 transmission oil drain and refilled, soon after it had same problem of shifting when cold start in the morning. After adding 1/2 qt more of transmission oil problem was gone. You mention you have it changed at authorized, maybe ask them to check transmission oil level, or just bring it to toyota or lexus to check.
Old Jun 28, 2025 | 01:02 PM
GS4_Fiend's Avatar
GS4_Fiend
I would get the ATF drained and refilled. It takes 3 qts and use Toyota WS.
Julius071
Hybrid Technology
Jul 12, 2023 10:20 AM
Jeff32073
RX - 1st Gen (1999-2003)
Jul 24, 2019 05:08 PM
RX370
Nov 10, 2010 07:34 AM
rickyp39
Nov 5, 2010 12:18 PM
shikbas
Dec 2, 2004 01:22 AM
