2022 lexus rx 350 vibrations
Old Nov 22, 2024 | 06:29 PM
Maxijazz's Avatar
Maxijazz
5th Gear
Default 2022 lexus rx 350 vibrations
Hi, I know the topic of vibration has been discussed many times before. my lexus has 9000 miles . the center pipe was recently replaced.L-SB-0003-23. I noticed that after starting the car, the vibrations in the steering wheel, center console and driver's seat are less, much less. but the best thing is that these vibrations do not occur in the P position . appear in position R or D. in the P or N position they are almost imperceptible. maybe someone had this case. could it be a problem with the gearbox?
Old Nov 23, 2024 | 05:48 AM
ravenuer's Avatar
ravenuer
Sounds like you still have some exhaust vibration. When in reverse or drive, the engine rpms drop to a lower level, where apparently the vibrations originate. In park and neutral, the rpms go up where you have less vibes. Should have nothing to do with the transmission. Do you feel these vibrations while out on the road, or just while standing still?
Old Nov 23, 2024 | 08:48 AM
Maxijazz's Avatar
Maxijazz
5th Gear
Hi, the vibrations occur when stationary. But I have a problem with the gearbox jerking, I think between 1st and 2nd gear. I thought the vibrations and jerking would indicate a damaged gearbox
Old Nov 23, 2024 | 10:48 AM
ravenuer's Avatar
ravenuer
Being that you had the pipe replaced for the vibration TSB, I've read on here about some owners still having the problem. Didn't know you have shifting problems. I'd bring it to the dealer and have the transmission checked out.
Old Nov 23, 2024 | 04:32 PM
Maxijazz's Avatar
Maxijazz
5th Gear
I went to the dealer about the transmission and they can't see any problems with it. The Lexus is slowly becoming a real piece of ****.
Old Nov 24, 2024 | 02:31 PM
Lex2000TL's Avatar
Lex2000TL
Vibration may come from defective or damaged engine mount. Also, I suggest asking dealer to wipe out/reset “transmission memory”.
Old Nov 24, 2024 | 07:00 PM
Maxijazz's Avatar
Maxijazz
5th Gear
They did a reset. The service technician drove 30 miles, adjusted something, but it didn't help. I'll check the engine mount. I also heard that Lexus made a new mount that's better. I couldn't find any information about this mount
Old Mar 29, 2025 | 12:09 AM
ddmmtx's Avatar
ddmmtx
1st Gear
do you have any updates?
is it because of a bad engine mount?
I have the same issue, I can feel the vibration when holding the steering wheel, either idle or driving.
Old Mar 29, 2025 | 03:04 PM
GS4_Fiend's Avatar
GS4_Fiend
It's the characteristic of this vehicle. We all have this problem.
Old Mar 29, 2025 | 03:56 PM
PhxBill's Avatar
PhxBill
I dunno, after years of driving pickup trucks and four wheel drives, this car rides smooth as silk.
Old Dec 1, 2025 | 08:31 PM
ocnsean's Avatar
ocnsean
1st Gear
did you get this vibration problem fixed? I am having this same problem and still could not figure out what is causing this.
Old Dec 24, 2025 | 07:07 AM
lexflana's Avatar
lexflana
I have a 2019 with 68K miles on it. Bought it CPO so still currently under warranty until June 2026. I have never felt this. Curious what ends up being the cause.
DebbieJ
RX - 3rd Gen (2010-2015)
Sep 6, 2024 08:02 AM
poormr
RX - 5th Gen (2023-present)
15
Apr 14, 2024 06:09 PM
joelake1
Nov 9, 2015 11:14 AM
