Check Engine Light? At <5K miles???
Old Jan 20, 2007 | 09:17 AM
LexusTime2's Avatar
LexusTime2
Default Check Engine Light? At <5K miles???
When I press the start button twice, the car does a normal system check. All the lights shut off except the CHECK ENGINGE LIGHT & BATTERY light. But when I actually START the engine, all the lights shut off. I took it to the dealer and they said it's normal to have the check engine light during the ON mode, as long as it turns off when the engine starts. The dealer said that it's normal and happens to all IS's. Is this true or are they just brooming me aside?
Old Jan 20, 2007 | 09:19 AM
Bichon's Avatar
Bichon
As long as the light turns off when the car is started, you are fine.
Old Jan 20, 2007 | 11:40 AM
BounceNY's Avatar
BounceNY
I also believe thats normal when you hit the start button twice without touching the brake.
If I remember correctly most of my older cars did the same thing...well the engine & battery icons would illuminate. But when the car is started, they turn off.
Old Jan 20, 2007 | 11:43 AM
nabisco's Avatar
nabisco
Every car I've owned does the same thing.
Old Jan 20, 2007 | 01:04 PM
Irishman06's Avatar
Irishman06
CL Folding 25,000
Yea, this is a standard thing. Ignition on with the engine not running throws a check engine light, usually because a sensor in the crankcase is reading no oil pressure.
Old Jan 20, 2007 | 01:07 PM
PNice972's Avatar
PNice972
every car does that......
Ladoo1980
IS - 1st Gen (2001-2005)
Apr 23, 2017 10:28 AM
esucaris1
Jun 10, 2007 09:18 PM
vasgs4
May 6, 2005 04:59 PM
mastella
Oct 8, 2004 01:55 PM
PearlLex
12
Aug 9, 2004 11:57 PM
