Clicking noise when braking on reverse
Old Apr 7, 2023 | 08:14 AM
Krishh's Avatar
Krishh
Default Clicking noise when braking on reverse
Hello...I have 2021 rx fsport
whenever i back out of my garage in the morning and when i first apply the brakes, i hear a clicking sound from the front . I think its coming from the brakes.
Is this normal? anyone else have the same issue?
Old Apr 7, 2023 | 08:35 AM
bamalam's Avatar
bamalam
Does it happen only when first backing out of your garage, but not when braking in reverse later? If so, it is very likely surface rust that accumulates on the rotors overnight. It is very common unless you live in a very dry climate. It's also harmless.
Old Apr 7, 2023 | 08:37 AM
Krishh's Avatar
Krishh
It sometimes happens couple of times later too. I went to the dealer and they said its the brake pad shift.
Old Apr 7, 2023 | 06:58 PM
Lexspeed's Avatar
Lexspeed
Yep, the noise is probably brake pads slightly shifting in the calipers. No problem.
Old Apr 8, 2023 | 08:20 AM
autotech13's Avatar
autotech13
No big deal, just annoying. It's the caliper pins that need some silicone brake grease.
Old Apr 11, 2023 | 04:00 AM
Xbowguy's Avatar
Xbowguy
yep my Tacoma does the exact same thing normal noise
Old Sep 27, 2023 | 08:35 PM
Krishh's Avatar
Krishh
Default 21 Rx F sport Brake clicking noise
Hello,
i am getting this strange clicking noise from the front right when braking. Also happens after braking when car is stationary and brake pedal is pressed all the way in.
Dealer simply said it needs to be more cosistent to fix it. But it happens all the time.
anyone else had similar noise?
Old Sep 28, 2023 | 02:26 AM
jcg0324's Avatar
jcg0324
Loose fitting brake pads is a common cause. Do you still have all the original brake components?
Old Sep 28, 2023 | 06:36 AM
Krishh's Avatar
Krishh
yes I do have all the original components....just 16k miles
Old Sep 28, 2023 | 07:22 AM
ravenuer's Avatar
ravenuer
Hello,
https://youtube.com/shorts/Z9ph23bF9...oyJrLk080KL4Gr
If it happens "all the time", ask the dealer how much more consistent he needs it to be?
joshua28
Suspension and Brakes
13
Feb 26, 2019 06:40 AM
liquidx
Sep 9, 2010 05:56 AM
Farino81
Jun 26, 2009 06:13 PM
Pat55
RX - 1st Gen (1999-2003)
Jun 25, 2009 05:02 AM
1994 LS400
Aug 22, 2002 05:44 PM
