2015 RX350 - P0303 Code, CEL, VSC - Help
Local WI Lexus dealer also said that they can't fix it, as the engine was already dismantled and they wouldn't know what to do next. They actually told us "we don't recommend further repairs".
Lexus corporate won't help us as we've contacted them.
Any ideas???
Local Lexus dealer also said that they can't fix it, as the engine was already dismantled and they wouldn't know what to do next.
Any ideas???
The original Lexus dealer probably did not disclose the problems and maybe the guys who sold it to you were unaware of them as you said it drives okay. Or they cleared the codes. You probably won't hurt it by driving it more. You may want to find a great independent Toyota/Lexus specialist to analyze & diagnose your problems before taking the next step which would be to........
Trade it in for another car. Do not waste any more money trying to fix it. Take your loss and get another vehicle. That it may need an engine rebuild that will cost more than the car is a great reason to trade it in.
Lexus corporate will not talk to you because there is no longer any warranty on the vehicle and you are not the original owner.
Next time you want a Lexus or Toyota you can join the Lexus Drivers site or Toyota Owners site and enter the VIN of the vehicle you are interested in and it will show you its dealer service history. CarFax cannot provide all of this information as it focuses on accidents and general service such as emissions tests. You should check the history of the lemon you just bought.
https://drivers.lexus.com/lexusdrivers/
https://www.toyota.com/owners/my-veh...E&gclsrc=aw.ds
(Unless of course the Lexus dealer said in their conclusion that they couldn't fix the issue.)
Could your WI dealer tell you the outcome of that repair? What was the outcome of the repair performed by the Lexus dealer? You deserve to know that.
Based of these answers, I would hazard a few guesses. First of which is to say that cylinder 3 is in the back, by the firewall behind the intake manifold, and it's a PITA to work on - your dealer probably just doesn't want to deal with it. A good independent shop might be more willing to take on the challenge, but of course there is no guarantee that they'd be skilled enough to find it either.
1) P0303 is misfire in cylinder 3. If it is a coil/plug issue, it would be a flashing CEL, which would indicate that you are doing some extra damage driving it around like this. Fuel is getting in but not burning due to no spark. That fuel is making it into the catalytic converter in extreme amounts, which could be burning it up.
2) But a flashing CEL is usually accompanied by serious drivability problems, like very rough idle and very low power. If it isn't anything like this, and the CEL is solid, that would indicate no fuel. Being that the fuel injector has been replaced, it could still be a wiring issue that is causing the injector not to fire. Or perhaps the fuel rail happens to be plugged right there - not so sure about this possibility, haven't played with fuel rails enough to know if it's possible for pluggage to occur and/or for it to only affect this one cylinder.
3) Another possibility, especially if the spark plugs were replaced just prior to the original repair, is that the intake manifold was not resealed properly (o-ring gasket at each intake port) and is pulling extra air into this particular cylinder, which could cause a misfire. Even if the plugs weren't replaced recently, the plastic intake manifold could still have an odd crack in it causing this issue - Sandi_K had an issue with their intake manifold, although that vehicle had 240k miles on it.
4) other more haphazard, less likely guesses: valve stuck open or closed? Perhaps broken valve spring, worn camshaft (this was problematic early in the 2GR life). Bad rings in the cylinder (no compression = no combustion = misfire). Bad fuel? If the car drives mostly normal, I would go here first - try a few tanks of 91 or 93 octane from another station. I doubt this is a case of bad fuel, but you never know. Based on how mild the symptoms are, I might even hazard a guess of a MAF or O2 sensor just starting to go bad, but those issues usually don't present themselves like this. Those would be the last things I change before trading the car, although I've cleaned MAF sensors successfully in the past for $10, so that might be worth a shot
Again, the likelihood of any of my above guesses goes up and down with how the car is actually behaving. And I do realize some of them are wayyyy out there (particularly in #4). But I just wanted to give you an idea of how much more stuff could be checked - maybe some of it has been already and just not mentioned or not connected with this issue. Good luck, keep us updated.
