New Android headunit
I have contacted my supplier about the touch screen situation, android screen should be touch screen [and the mouse is messy on that]. Regardless tomorrow morning I am going to try and clean it all up!
Here is the link:
I have one of the usb extenders, connected directly to the factory USB [and it appears to work properly], cannot confirm carplay works yet but it should]. With the cable posted above, the factory usb port should allow us to use carplay.
And the other usb extender goes into the glove compartment box.
Apple carplay DOES work with the factory USB port using the usb adapter I posted.
Although touch screen does not work, I realized I could plug a mouse in for the time being and easily navigate the menus! This worked
Working with the supplier right now to get the touch screen stuff figured out, it is the only flaw I have encountered.
This is an update for everyone following, probably the most important one yet!
The unit works amazingly well! It is crisp, it is very attractive, and it is quality. The factory OS loads at normal speeds [5 seconds ish?] The android OS takes literally 10 seconds to load which is nothing.
Apple carplay works flawlessly through the factory USB cable using the adapter I posted previously, and touch screen now seemlessly works on the tablet [I have NO idea how this was fixed, it just started working]. Regardless, I am extremely happy with the product.
Here is a link that I purchased from: https://www.alibaba.com/product-deta...15a82fc2NsFAzv I messaged the supplier and specifically stated I wanted the following specs
Resolution: 1920x720p
Ram: 4gb
Cpu: 8cores
Rom: 64gb
Operating system: Android 9 [I found out it is android 7.1, which is the highest standard available for our vehicles so no big deal].
Time for the review: This is VERY easy to install, it is plug and play on all accounts, I did not plug in the microphone as there is really no need to, I did however install the speaker and gps antenna, they both rest behind the head unit [they have sticky tape to set them firm which I did]. Regardless, the unit operates well. Apple carplay using the carlink kit [wired not wireless] works in seconds of starting the car, and using the automatic shortcut through iphone all of the sounds go through factory bluetooth with 0 issues whatsoever. It sounds crisp, it is responsive, loads fast and looks spectacular.
WARNING: The screen appears to scratch VERY easily. I am talking to the supplier about a screen protector, This unit did not have a protective film over it, or if it did it is so insanely tiny I cannot even see it or peel it. I can't wait to test this out on an actual road trip, but first impressions + 30 minutes of driving are very good so far.
Oh and for carplay: Something other carplay solutions cannot offer yet, all of the factory controls work with carplay on the steering wheel, this is huge! If I hit the call button Siri comes up, if I change tracks the song changes. Overall I am satisfied.
Ram: 4gb
Cpu: 8cores
Rom: 64gb
WOO good for you. Im waiting till the sun goes down to install mine. Too hot right now without an indoor garage.
I will update once i complete mine as well
