Floor Jack Height
Old Nov 5, 2019 | 12:35 PM
cyponline's Avatar
cyponline
Default Floor Jack Height
Does anyone know the height requirement to be able to remove the rear tires?
Would 18" be enough?
Thanks.
Old Nov 5, 2019 | 02:40 PM
Clutchless's Avatar
Clutchless
A floor jack will work just fine. Be sure to use jack stands for safety backup. I use one all the time. You can always put a thick piece of wood on top of the platform for a little more elevation. Such as 2x6 decking.
Where in VA are you? I am in the DC suburbs.
Old Nov 6, 2019 | 06:31 AM
afpj's Avatar
afpj
For our 2010 RX 359 AWD, the 18 in. Lift height of my floor jack works fine front and rear, without a wood block, but depends on how much extra room you like. Use jackstands as well per clutchless
Old Nov 6, 2019 | 08:34 AM
salimshah's Avatar
salimshah
25 Year Member
I have piece of 4x4x4(cut) lumber and I have cut (dado) a slot in the middle. I have taken off 1/16~1/8 from one side of the slot to mimic the surface of the scissors jack. I use that piece to give me the additional height as well as use it on seam (recommended) jack lift points.
[Note due to the top not being level (due to 1/16" cut), the block goes one way on the floor jack.]
Salim
[Study the grain of the wood and choose the slot properly]
Old Nov 6, 2019 | 10:58 AM
cyponline's Avatar
cyponline
I'm planning on using Jack Stands. Thanks for the safety tip. I'm close to IAD.
Thanks. With Blackfriday around a corner I'm looking at getting a new floor jack. Now I know all the 3 ton floor jacks i have been looking at will work.
Salim
Thanks. I'm hoping not to have to us additional wood block to raise the car.
Old Nov 6, 2019 | 03:56 PM
Clutchless's Avatar
Clutchless
I have a couple of Harbor Freight jacks that work as well as the worn out Craftsman floor jacks they replaced. There is a Harbor Freight in Sterling Park and another in Manassas. Get a 20% off coupon online.
I also have wood blocks cut from 4x4 hardwood with a slot in them for the side rails and use them on my jack stands.
Old Nov 7, 2019 | 05:33 PM
RX in NC's Avatar
RX in NC
I also have a low-profile Harbor Freight floor jack that has a range from about 5 inches to about 22 inches. I paid $74 for it (with the aforementioned coupon) 3 or 4 years ago. Well worth the cost - I use it on all four of our vehicles.
Old Nov 8, 2019 | 06:18 AM
Clutchless's Avatar
Clutchless
I have one of those low profile jacks which was helpful when I had a G35 Coupe as it was so low to the ground. My other floor jack is normal height. It is very convenient having 2 floor jacks on some projects.
Old Nov 8, 2019 | 08:43 AM
Non's Avatar
Non
I measured the jack height while working last night:
For the front, the tires left the ground at 14 inches.
For the rear, the tires left the ground at 17 inches.
I positioned the jack per manual:
Old Nov 9, 2019 | 05:53 PM
fastnoypi's Avatar
fastnoypi
i just pulled a rear tire off my 2010 RX last week. Used my HF 3 ton jack...max lift is 18in but you don't even need to get it that high to remove them. That spot where member Non describes in the pic by the rear diff is where i lifted. I placed a cut piece of 2x6 as a jack pad. Always work with a jack stand.
Old Nov 11, 2019 | 09:51 AM
LS1's Avatar
LS1
my 3 ton low profile harbor freight has lifted my old yukon many times. should make easy work out of the lexus
Old Nov 12, 2019 | 07:55 AM
cyponline's Avatar
cyponline
Thanks all for the additional information.
I'll have decided to buy DAYTONA during the Blackfriday sale for $89.99.
https://www.harborfreight.com/3-ton-...nge-64200.html
Lift height of 5 in. to 18-1/4 in.
unless the Costco jack goes on sale for $99.
https://www.costco.com/3-Ton-Profess...100222458.html
Lift Height: 4" to 18.6"
Old Nov 12, 2019 | 08:54 AM
Clutchless's Avatar
Clutchless
The Daytona is a great choice. My local garage where I go for the Virginia state annual safety inspection (I was there yesterday) has the low profile Daytona that their inspector uses to pull wheels and check brakes. It appears to have held up well in that commercial setting. It sees more use from him in a week than you would give it in a year!
Old Nov 13, 2019 | 06:04 PM
salimshah's Avatar
salimshah
25 Year Member
The only downside is the weight. If that is not an issue for the owner .. it is a great jack.
Salim
Old Jun 29, 2023 | 09:59 AM
mnalep's Avatar
mnalep
10th Gear
How much height is required by a floor jack, in order to lift the RX350 to remove tires?
Harbor Freight (Pittsburgh/Daytona brands) has 3 jacks that l am considering:
- Pittsburgh 2 ton claims 15 7/8" for $185 (37.5 lb weight) , and,,
- Daytona 2 ton claims 16 3/4" for $209, (42.7 lb weight), and,
- Pittsburgh 2.5 ton claims 18 5/8" - $219, (54 lb weight)
I'd like to get the lightest weight (back issues) - for $185 - but I am not sure its max height of 15 7/8" is enough?
(Some here have said 14" for the front - is required, but that 17" for the rear - is required.)
