Brake Lights Stopped lighting up
Old Jan 8, 2019 | 08:44 PM
raylor4's Avatar
raylor4
Thanks for giving props to America's Tire for their excellent customer service. Looks like they saved you $1k. I hope you pushed some lunch money into the guy's pocket. I assume it was a guy. : ) Ray A.
Old Jan 9, 2019 | 08:32 AM
lexusrus's Avatar
lexusrus
One of the same......
Originally Posted by RX in NC
In my neck of the woods Discount Tire also fixes flats for free (they remove the tire from the rim and patch it properly). I believe Discount Tire and America's Tire are owned by the same corporate entity.
Old Feb 25, 2019 | 02:34 PM
edsrx350x2's Avatar
edsrx350x2
where is the location of the resistor?
having the brake lights problem
Old Feb 25, 2019 | 02:36 PM
edsrx350x2's Avatar
edsrx350x2
how did you diagnose that the LEDS are burnt out?
Old Oct 5, 2021 | 01:19 AM
CanadRX350's Avatar
CanadRX350
Solved! Came across the below website and fixed my LED brake light that was out. It’s a thin wire that is tight and easily rips out of the connector and you need to lengthen and reattach in the connector, done:
http://takakiauto.com/blogs/kunio/20...00-repair-cost
Old Feb 6, 2023 | 12:12 PM
shorts868's Avatar
shorts868
1st Gear
Default The problem is the wiring
The wiring that’s going to the led brake light is short, so when removing the holder for the park bulb, you accidentally breaks the wire, I’m just finished extending the wires and getting brake light again after losing it while changing park light bulb
SIRLEX400
Jan 26, 2012 03:40 PM
Aziz1786
IS - 1st Gen (2001-2005)
Sep 26, 2010 08:58 PM
magneti
Jun 2, 2010 08:41 PM
Saiji
Sep 18, 2008 12:48 PM
