engine block heater in cold climes
Old Nov 6, 2018 | 07:01 PM
Tony29's Avatar
Tony29
10th Gear
Originally Posted by budwom
With synthetic oil, I just don't see the need. I live in Northern Vermont, it routinely gets to -20--30 here, sometimes colder, and I've never seen the need with our 2013....I used block heaters years ago with some large lumbering American car engines, but the world has changed.
At those temps, the only thing I do is refrain from big acceleration for the first mile or two, that's it.
Thanks, however the conflicting responses in this thread make it harder for me to come to a decision. You did not mention if you parked outside at nights, like I have to do. Anyways, I will be getting quotes for installing a block heater both from local Lexus and Toyota dealers. Experience has shown me that Toyota dealers do the job as well with much lesser labor charges.
I'm still good until the end of this month, since my vehicle was parked outside my garage in Toronto right through last winter with temps falling below -20 C and no problem.
Old Nov 7, 2018 | 05:24 AM
paperthin's Avatar
paperthin
I agree with budworm. I am on my second diesel car and they have never ever had a problem, my first diesel didn't even come with a block heater either. I too am in the GTA with a car outdoors. My wife's 2010 450h has never ever had a problem in the winter.
Old Nov 7, 2018 | 06:17 AM
Airbalance's Avatar
Airbalance
Originally Posted by Tony29
Hello,
I have just moved to Saskatoon SK where winter temps sometime go below 40 deg C (with windchill). My RX350 has approx 105k km and could someone please tell me if the RX350 has an engine block heater or heating coils around the cooling system to connect to an AC plug outlet, which is provided in most external parking stalls here to heat up the car engine/oil during winters..
I've been informed that vehicles sold in Northern Canada are all fitted with such arrangements, however I don't see any electrical chord around the front end.
I would appreciate any feedback on this issue.
Tony
i still cannot believe that someone is moving to Saskatoon on purpose 😱😄
Old Nov 7, 2018 | 10:11 AM
tus's Avatar
tus
While I do agree that the OP probably does not need a block heater, one would make life much easier. If for nothing else, and even though the factory heater indirectly heats the coolant, getting into the thing and having the heat work right away is always nice.
FWIW, here are two personal weather stations sharing data on Weather Underground, one in Saskatoon, SK, and the other in Greensboro, VT. Take a look at the current temp as well as the historic ones recorded in Jan and Feb.
https://www.wunderground.com/persona...20181107/myear
Old Nov 7, 2018 | 11:39 AM
heshamos's Avatar
heshamos
Block heaters "directly" heat the cooling system (as opposed to the oil)
Old Nov 7, 2018 | 12:14 PM
tus's Avatar
tus
The OEM block heater for the OP's RX is a cartridge that gets inserted into the metal block and does not come into contact with the coolant or oil.
It heats the block itself, which in turn will warm/heat the coolant and oil in the block. Doing it this way makes the thing easier to install and you don't have the risk of creating a coolant leak like you would with the old type frost plug heaters that heated the coolant.
Old Nov 7, 2018 | 12:26 PM
heshamos's Avatar
heshamos
Thanks so much for this piece of information. I've never dealt with this kind of block heaters before. Although it sounds much "cleaner" to install without creating puddles, I'm just scratching my head since trying to warm the block instead of directly warming up the coolant/oil makes the heat dissipation much greater. Well, I'm sure Lexus engineers know what they are doing ..
Thanks again..
Old Nov 9, 2018 | 06:40 AM
Droid13's Avatar
Droid13
I will cruelly add to your confusion. Being north-east of the Toronto core, and last winter having been very, very cold we saw quite a few nights where the temps at night went below -30C (one night went as low as -35C, and that's NOT wind chill values). While my RX is parked in garage, we have an old 2004 Sienna that parks outside with near 250,000km on it. It turned over a bit slow in the early morning on these brutally cold days but fired up every time. Even when the original OEM battery was 10 yrs old and barely could turn the engine over in the winter, it still started (finally replaced the battery at 11 yrs and the current has 4 yrs on it) So to block heaters I say bah, humbug!
Block heaters were definitely needed back in the days of the carburetor, I've had the joy on super cold mornings in my early driving days of standing over carbs spraying quik start, booster cables out, tripping over block heater cords, etc. Those were NOT the good ole days. These days fuel injection systems are highly competent at starting in really cold temps. As long as your engine and sensors are in good condition, just make sure your battery is good too. The battery is really going to be your go/no-go component.
Old Nov 9, 2018 | 10:59 AM
salimshah's Avatar
salimshah
25 Year Member
There seems to be a confusion between human comfort/convenience and machine requirements.
With petrol/gas engines you need to make sure the coolant has not expanded [in the confines of a pressurized environment) to burst something and oil is able to flow and the battery can produce enough juice for starter to turn the engine.
When it gets to diesel engines, the ignition would not happen till the compressed air (during compression stroke), reaches high temperature. With cold chamber, it takes a whole lot longer [due to high compression --> excessive current draw from battery -> usually the battery dies before the temp can be raised to fire the diesel engine]. There thy have to install heater plugs etc and even put a blanket on the battery, and in many places, just let the diesel engine run,
Back to gas based personal use vehicles ... you make sure there is the right antifreeze and the right viscosity of oil and then every thing is for human comfort.
Salim
Fixman
Aug 3, 2015 12:45 PM
Eagleguy
Jan 3, 2014 04:52 PM
mikebatman
Apr 8, 2013 01:29 PM
georgie39
RX - 1st Gen (1999-2003)
Oct 30, 2010 07:05 AM
Briankim79
Hybrid Technology
Dec 31, 2007 10:42 AM
