Interior Exterior Lights
Is there a post on all the light numbers of the RX350? I wanna upgrade to LEDs, and there are a butt load of lights to change. I don't wanna pull all the covers to find out.
Please indicate year of production of yours. I've replaced all with LEDs. Mine is 2013 RX350 F-Sport
Check here for a start: https://www.superbrightleds.com/vehi...=44&model=1408
2010 RX350 AWD. Thanks for the info. I really didn't think those 2 sites would have had a listing by vehicle
Just be aware that although I believe that Sylvania will probably offer the highest quality (and price), this will not mean that they are the brightest especially with the 194/168 that is being used in the interior almost everywhere. You will need to read a few reviews here and there. LED technology has come a long way.
When it comes to signal lights, I would use Sylvania for sure as I would trust them the most. Please don't use resistors with Signal LEDs.
Most of the major automotive bulb makers have application guides. VLEDS will also tell you which bulbs you need and for some applications they have standard & high output options as well as different color temperatures.
There are a lot of lights but I only ended up swapping out the dome, cargo, footwell, door, puddle, vanity and reverse lights. All of those except cargo and reverse are 194's. Cargo is DE3022 though the ones from VLEDS seemed a bit long. Reverse is 921. I went with high output for puddle, door, cargo & reverse lights and standard for all the rest. Even the standard bulbs are brighter and more even than stock.
