Door handle not Unlock/lock
Old Apr 22, 2017 | 07:16 AM
rafaelp's Avatar
rafaelp
Default Door handle not Unlock/lock
Hello I Have a 2010 Lexus RX350 , when I touch the driver door handle the door doesn’t unlock or lock, the passenger door works fine , this only happens on the driver door, I have the look settings to unlock all door when I grab the handle , bur driver door isn’t working, please advise
Thanks
Old Apr 23, 2017 | 04:41 AM
SteveCraig's Avatar
SteveCraig
Check it from the inside lock button. If the door will lock I'd believe the lock solenoid is working & you have a problem with the exterior switch.
If the door will not lock I'd believe you have an issue with the lock solenoid or the harness leading to it.
Not sure how handy you are but getting the interior door panel off is not a big job with a little patience.
Old Apr 23, 2017 | 08:20 AM
rafaelp's Avatar
rafaelp
thanks for your quick response , the inside lock button works and the key fob works good to , I think the problem may be in the sensor that detects the key fob,(if there is a sensor for that).
when I approach the passanger door the light below the mirror turns on , that doesn't happend on the driver side .
is there a sensor that detects tha key fob for each door? Or what else do you think may be the issue
Old Apr 23, 2017 | 02:53 PM
SteveCraig's Avatar
SteveCraig
Don't know the system very well but elimination of other issues can go a long way to narrowing down the source of your problem.
I expect the key fob sensing unit would send a signal to the exterior lock pad. You close the signal with another conductor, possibly a ground, to engage the lock solenoid.
If it were mine I would pull the door panel to check for a loose/corroded connection at the door handle.
Old Apr 24, 2017 | 09:40 AM
H0P's Avatar
H0P
Have you tried the other key fob? Might have weak batteries?
--Hop
Old Apr 24, 2017 | 11:41 AM
rafaelp's Avatar
rafaelp
--Hop
When I bought my Lexus it was used and had only one key, I will change battery to eliminate possibilities. The strange thing is that it works perfectly on the passenger door.
Old Apr 24, 2017 | 07:23 PM
N4TECguy's Avatar
N4TECguy
this tells me it's an issue with the sensor on the car. According to my manual, there are several sensors for various zones around the car. I bet the driver's door one has gone bad.
Old Apr 25, 2017 | 05:50 AM
rafaelp's Avatar
rafaelp
that is my assumption as well, is there a way to know the part number for the sensor and location on the vehicule?
Old Apr 25, 2017 | 09:08 AM
mandyfig's Avatar
mandyfig
It could be that this function (which in your case is disabled) is set at the Lexus settings. Did you purchase this car brand new?
Speculation is that the previous owner does not want the DR side door to open when the owner approaches the car. It must be a personal security preference.
SonicISF
Mar 18, 2017 06:53 AM
Silvermtb6
Jul 15, 2012 11:53 AM
jsc8686
Mar 7, 2012 06:08 PM
Slow_Sc3
Feb 14, 2009 03:24 PM
tuan92129
Dec 21, 2007 08:20 AM
