Replacement wiper blades with instructions (merged threads)
Old Jan 10, 2018 | 07:47 AM
  #121
Clutchless's Avatar
Clutchless
Depends if it is Japan or Canada built. Look here https://www.mylparts.com/?p=catalog&...=wiper%20blade
Old Jan 10, 2018 | 08:05 AM
  #122
BP1203's Avatar
BP1203
Thanks, clutch. Found out through digging in old posts they're made by Trico. Amazing how they can gouge you at the stealership. I take my wife's RX to Toyota-went in for oil change. When advisor said $65 for wiper blades, I laughed so hard I cried.
Old Jan 10, 2018 | 09:04 AM
  #123
BP1203's Avatar
BP1203
Clutch: I consider you an expert on all things Lexus. Was wondering about spark plug replacement on the RX-almost 70k on the clock. Will definitely replace at 90k-bought this car three weeks before my daughter was born. After 10 years I'll get the boss something else to drive but I want to keep this car as a third car and eventually give to my daughter when she turns 16. I want this car to last forever and know the little things are what keep them humming-your advice?
Been trying to search this thread for info and I can't find the RX spark plus thread.
Old Jan 10, 2018 | 09:28 AM
  #124
Clutchless's Avatar
Clutchless
Lexus says do not do it until about 100,000 miles. Considering you have to remove the intake manifold (plus a bunch of other stuff) to get at the rear ones and the job takes several hours, or several hundred dollars at a shop, I would wait until it is needed.
Check out the maintenance sticky sub forum here for the Highlander as it is a mechanical twin http://www.toyotanation.com/forum/12...ion-2008-2013/
I would do a couple transmission drain and fills or a flush (at the dealer) if you plan to keep it a long time.
Yep, Trico makes the blades. I lucked into a clearance sale of them at Rock Auto a few years ago because they were in NAPA boxes and being discontinued. I stocked up as they were about $3 a blade. Luckily both my vehicles take the same blades!
Old Jan 10, 2018 | 09:47 AM
  #125
iolmaster's Avatar
iolmaster
Originally Posted by BP1203
Anyone have a part # for the blades? Not getting hit over the head by Lexus parts price, but will look for a Toyota parts dealer online...thanks in advance
The OEM blades on my 2015 are Denso low profile style. The Denso numbers are 160-3126 and 160-3122. Both are about $20 on Amazon. I do not know the Lexus or Toyota numbers. The blades are identical.
Old Jan 10, 2018 | 09:55 AM
  #126
Clutchless's Avatar
Clutchless
Is that for the rubber refill? I don't know the metal blade part number either, but recall a few years ago the Trico Neoform or something like that was the OEM Lexus blade for 2010-2012 models (more or less) according to a friend who is an expert on such details. The blades were Teflon coated. The ones at Rock Auto were identical. Denso must also be an OEM blade supplier and they supply so many other OEM parts such as Nav systems etc.
Old Jan 10, 2018 | 11:39 AM
  #127
iolmaster's Avatar
iolmaster
Those part numbers are for the entire blade, not the refill. For that price, I am not going to refill blades. The local Toyota store wanted about $36 a piece for the same thing. I took one out of the box and it is the Denso. Not unlike many items at Toyota and Lexus.
Old Jan 10, 2018 | 02:18 PM
  #128
BP1203's Avatar
BP1203
Thanks, Clutch. Changed the tranny fluid at 63k at last oil change. I'll change that every 60k, differential every 75k. Don't do any towing, so I figured those intervals would be safe.
At 90k I figured I'd replace struts all around, spark plugs, drive belt-
Thanks for your input.
Old Mar 9, 2018 | 06:36 PM
  #129
tempestv8's Avatar
tempestv8
Part number for the 3 rubber wiper blade inserts/refills, Lexus part number:
Fronts: (2 part numbers because they are different lengths)
8521468020
8521453080
Rear:
8521410100
In Australia they are fairly pricey items. Converted to USD the set of 3 rubber inserts come to $32 (AUD $42)
However I will only use genuine OEM replacements as 3rd party blades simply don't last as long as OEM, just as others on this thread have alluded to.
Trivia: On the wiper rubber insert, you can generally see when the wiper blade is manufactured. There will be a string of double digits and dots. So if the wipers are made in 2017, it will have 17 followed by some dots to indicate roughly the month. My dealer didn't have stock of the wiper refills so he ordered them in. At least I know the refills have not been sitting on a shelf for a long time.
Here is a picture of my one of my old rubber blade inserts:
So I can deduce that it's been on the vehicle for a few years.
Last edited by tempestv8; Mar 10, 2018 at 04:29 PM. Reason: Clarified pars are "inserts" not blades
Old Mar 10, 2018 | 05:05 AM
  #130
iolmaster's Avatar
iolmaster
Originally Posted by tempestv8
Part number for the 3 wiper blades, Lexus part number:
8521468020
8521453080
Rear:
8521410100
Trivia: On the wiper rubber insert, you can generally see when the wiper blade is manufactured. There will be a string of double digits and dots. So if the wipers are made in 2017, it will have 17 followed by some dots to indicate roughly the month. My dealer didn't have stock of the wiper so he ordered them in. At least I know the inserts have not been sitting on a shelf for a long time.
Here is a picture of my one of my old blades:
I assume you know that the OEM blades here in the states are just Denso blades that can be had through Amazon or ebay. Nothing special. I don't know if they use other brands for the rest of the world.
Old Mar 10, 2018 | 01:49 PM
  #131
tempestv8's Avatar
tempestv8
Interesting. I was not aware Denso made wiper blade rubber inserts. Do you have Denso part numbers? I did a quick search on eBay Australia and Amazon Australia but found part numbers which I couldn't correlate back to the Lexus RX. Would be handy to have the Denso part numbers - I could buy them next time, although looking at the prices on eBay, the random ones I saw seem much dearer than the Lexus dealer's pricing.
If you have part numbers and/or pricing please post onto this thread.
Old Mar 10, 2018 | 02:34 PM
  #132
iolmaster's Avatar
iolmaster
You said wiper blades, not inserts. I do not know if the inserts are made by Denso. I do know that the blades that came on my 2015 are Denso. Just to give you an example. The 26 inch blade for the drivers side is $23.30 on Amazon here in the states. In my opinion, it is not worth it to try to refill them (even though they are refillable) for the difference in price. Just my opinion. The 26 inch is part number
160-3126.
Old Mar 10, 2018 | 04:12 PM
  #133
tempestv8's Avatar
tempestv8
OK, I've edited my original post to clearly state that it's the rubber blade inserts that I'm referring to, not the blade assembly. I see wiper blade assemblies for sale but can never figure out why there is a need to replace all that when it's just the rubber bit that has deterioriated. As an analogy, if my rubber tyres were worn, I don't see the need to replace the wheels as well. Not unless I wanted a different "look".
Thanks for supplying the part number for the Denso blade, might be useful for someone actually needing to replace the whole wiper blade assembly.
Old Mar 11, 2018 | 08:59 AM
  #134
Randyp1234's Avatar
Randyp1234
...The 26 inch blade for the drivers side is $23.30 on Amazon here in the states. In my opinion, it is not worth it to try to refill them (even though they are refillable) for the difference in price.
$23.30 for one blade vs. $18.72 for all three refills isn't worth it?
https://www.ebay.com/itm/252528472473
Old Apr 18, 2018 | 11:50 AM
  #135
erom43's Avatar
erom43
Question Special RX350 rear wiper replacement??
I went to replace the rear wiper on my 2013 RX350, and the 16" blade did not seem to work. Do I need to get a special replacement for that blade. I did see that Trico makes one that does look like it would work. However, I have not seen anywhere that a special blade was required. I have even seen regular Goodyear blades advertised as replacements for this car. I don't mind ordering the Trico, but I do already have an Anco, and would like to know if it can be adapted. Thanks.
