Odd noise at engine start-up?
Old Nov 16, 2013 | 05:54 AM
RickC5's Avatar
RickC5
Default Odd noise at engine start-up?
Our "new" 2010 RX is our second Lexus with fobs & push-button start. When I push the start button to start the engine, I first hear a one-second "BZZT" noise from behind the instrument cluster, then the engine starts. This happens every time I start the engine, but I've never heard a noise like that in our 2008 ES350. So I wonder if this is normal? Does anyone else hear this odd buzz noise just before your engine fires up?
Old Nov 16, 2013 | 06:59 AM
2010morx's Avatar
2010morx
Our 2010 Rx 350 does not make this noise.
Old Nov 16, 2013 | 08:35 PM
RXSF's Avatar
RXSF
my 2011 does make that noise. I think its from the fan or motor that cools down the nav screen
Old Nov 17, 2013 | 04:35 AM
RickC5's Avatar
RickC5
Hmmm. Not sure that's it since we don't have NAV in our RX.
Old Nov 17, 2013 | 10:27 AM
RXSF's Avatar
RXSF
hah, then I really don't know. But I know its like two short bzzzz sounds about two seconds after you have pushed the start button
Old Nov 18, 2013 | 09:37 AM
SteveCraig's Avatar
SteveCraig
Sounds like a relay coil/contacts chattering. Not present on our RX but present on our Accord.
No real worries other than the minor noise.
Might be an easy fix if you knew just where the relay was & could reach it without too much dis-assembly. My bet it's a <$25.00 part.
Coil needs a solid 12V to pull the contacts in, works just like an electric solenoid.
Pitted contacts will cause chatter, dirt/dust between the contacts will cause chatter, low voltage <12V may also cause the chatter.
What condition is your battery in ?? Original to the car ??
Old Nov 18, 2013 | 10:55 AM
RickC5's Avatar
RickC5
Yeah, that's what it sounds like.
Battery appears original, but the RX spent the first 3 years in Arizona, & that heat can trash a battery quicker than cold.
Rjtz
Jun 5, 2022 10:39 AM
Naskos
Hybrid Technology
Jun 6, 2019 09:22 PM
zhenger16
Apr 29, 2017 12:03 PM
Mr. T
Mar 11, 2011 04:48 AM
E12ic46
Hybrid Technology
Nov 13, 2010 02:44 PM
