the climatre control in my RX is set to 72F-when staring RX in the morning, if outside temp. is the same 72F, there is no air flow from the vents, and the fan is Off.
To get the air from the vents, I have to lower the temp. setting to 71 or better to 70F, and then the air starts coming out.
Is it normal operation of the climate control?
In other vehicles I had before, the climate control would still produce air flow, at the requested temp. (in my case 72F), even if the outside temp was the same 72F.
try to wait a few minutes after starting the RX and the air will flow.
i get the same scenario as yours.
pulling out from the garage there is no air... yet.
BUT as i reach the side street and as i make my way to the freeway ramp
the air starts to come out, with the fan at its lowest level.
