Need advice on TPS warning
Old Nov 23, 2010 | 11:27 AM
krypttic's Avatar
krypttic
Default Need advice on TPS warning
This morning, upon start-up, the Tire Pressure Sensor (TPS) came on for the first time ever. I immediately got out and checked the air levels. The four tires ranged from 29.5-31 PSI. Is 29.5 low enough to make this sensor come on?
Today was one of the first cold mornings in Phoenix (45º outside when I left the house). I'm sure this is why the pressure was lower than the 32 PSI I filled it at last week, but I didn't think a few PSI would trip the sensor like this. I'll put a little more air in when I get home today, but I'm still wondering what's going on.
Thoughts?
Old Nov 23, 2010 | 11:34 AM
krypttic's Avatar
krypttic
I just read on another thread that the TPS trips below 30 PSI. I guess that explains it. I suppose I'll have to fill at a higher pressure than the 32 PSI recommended to avoid these low pressures when it's cold outside.
Old Nov 23, 2010 | 12:18 PM
kitlz's Avatar
kitlz
No, I don't play soccer!
The warning can start as low as 30 PSI. It happened to me over the summer. The internal reading is too low by a pound, at least for me. So I resort to manually checking all tires.
Old Nov 27, 2010 | 12:10 PM
tazdevl's Avatar
tazdevl
Check the pressure in your spare.
Old Nov 27, 2010 | 12:17 PM
Joeb427's Avatar
Joeb427
Unlike the previous generation RX with matching alloy wheel and full size spare,the new generation has a spare is a temp tire.I doubt it has a pressure monitor.
little2576
Jan 5, 2012 09:34 AM
dcurcio
GX - 1st Gen (2003-2009)
Oct 17, 2011 07:57 AM
twister
Dec 24, 2007 07:11 PM
JohnnyCake
Apr 29, 2007 10:12 AM
9520G
Sep 13, 2006 04:54 PM
