power trunk door
Old Oct 11, 2011 | 04:51 PM
  #121
rowfei's Avatar
rowfei
Brought my 10 RX350 to the dealer for the power trunk door. Just got a call from Dealer saying they could not find any information from the techadvise regarding this change...... Perhaps I will need to try it from another dealer.
Old Oct 11, 2011 | 07:26 PM
  #122
LexRexBlue's Avatar
LexRexBlue
Reading these posts I can't believe how many Lexus service departments don't know and are too lazy to find out how to set the trunk opening.Since it was available on generation 2 many customers are accustomed to the convenience. My service advisor always will look into (and finds solutions) to anything he doesn't know. Mine is set to open on one push on the flat part and lock the car on the round part.
Old Oct 12, 2011 | 08:04 AM
  #123
MEP7557's Avatar
MEP7557
Originally Posted by djkidkris
Well no because the auto up starts immediately. After it beeps and the auto up initiates press the button 1 more time and the motor stops and then you can manually lift the rear door.
Thank You for this one. After owning the RX as long as I have I am still learning things it can do. This is great to know as sometimes I don't want to wait for the door to open automatically, it is on the slow side. When hands are full waiting is not a problem. Makes me love my RX even more.
Thanks.
Old Oct 12, 2011 | 12:23 PM
  #124
DunWkg's Avatar
DunWkg
Originally Posted by TheSnowman
For instance, it was over a year before I accidently discovered the Hill Assist feature; anyone else have late discoveries to share?
Just recently someone mentioned the zoom out-zoom in switch by the remote touch joy stick could be used for scrolling in any screen with a scroll bar. Handy.
Old Oct 12, 2011 | 06:04 PM
  #125
BatmobileX's Avatar
BatmobileX
I haven't read this whole thread but I just wanna say that when I press the trunk lift button inside the car, the one next to the gas cap button, nothing happens, so I think that was not programmed.
Old Oct 12, 2011 | 06:06 PM
  #126
happy1977's Avatar
happy1977
^You have to press the unlock button first for all doors, then it'll work.
Old Oct 12, 2011 | 06:12 PM
  #127
BCRCornet's Avatar
BCRCornet
The transmission must be in "PARK", otherwise nothing happens when you push that button.
Does that help?
Old Oct 12, 2011 | 06:20 PM
  #128
cafpaf's Avatar
cafpaf
Make sure that you also HOLD the button down for at least two seconds. Also please understand the button inside the car does not need to be reprogrammed. Only the button on the outside above the license plate needs to be reprogrammed.
Old Oct 12, 2011 | 06:23 PM
  #129
LexRexBlue's Avatar
LexRexBlue
For the inside trunk button to work don't you first have to do something in the glove compartment? I remember having to do that when mine was brand new.
Old Oct 12, 2011 | 06:24 PM
  #130
kitlz's Avatar
kitlz
No, I don't play soccer!
If the tail gate doesn't work from inside, open the glove compartment and look for a button on the lower left. Press it once and then try opening it again. Someone must have disabled it.
Old Oct 12, 2011 | 06:50 PM
  #131
BatmobileX's Avatar
BatmobileX
I will try this in the morning, thank you!
Old Oct 12, 2011 | 07:02 PM
  #132
kitlz's Avatar
kitlz
Great. I should have mentioned to check the button after unlocking all the doors like happy said with the vehicle in park like BCR said. It could have easily been pressed accidentally when something was placed in there. Happened to me. Next you'll have to get the tail gate button programmed. That's for another day.
Old Oct 22, 2011 | 06:33 PM
  #133
Nogee's Avatar
Nogee
Default Re-programmed now button on FOB not working
I had the rear hatch re-programmed as described in this thread. I was pretty excited to have this feature.
But I noticed today that the button on the fob to activate the power hatch no longer works.
Is this what happens when you re-program the hatch? I was hoping that the fob would also activate the power hatch.
Comments?
Old Oct 22, 2011 | 06:39 PM
  #134
MEP7557's Avatar
MEP7557
The FOB should still work the hatch door. Make sure you hold the button down for 2-3 seconds.
Old Oct 22, 2011 | 06:41 PM
  #135
AlexB's Avatar
AlexB
Comments?
I believe you now have to fully unlock the vehicle with the remote (press unlock twice) before you can open the rear hatch when the one touch open feature is configured. For this reason, and to avoid the possibility of the hatch hitting something when opened in confined spaces, I chose to stay with the default setting where the button on the hatch only unlocks it and you have to manually raise it.
