auto ventilation question
Old Dec 9, 2009 | 09:46 PM
garfull's Avatar
garfull
Default auto ventilation question
For those with nav, with the fan on and the ventilation set to recirulation and auto on (both lights on that button lit) is the ac on? I have the auto ac set to off in the customized settings. The ac stays off with the std auto button but why does it come on when auto ventilation is set?
Old Dec 10, 2009 | 08:39 AM
davesmith's Avatar
davesmith
Automatic Recirculation Control*1=Models with navigation system
Automatically changes the air inlet mode to fresh air or recirculate mode according to the level of harmful elements in the outside air, cabin temperature, and outside temperature. Standard (Not Customizable)
hope that help answers it
Old Dec 10, 2009 | 03:36 PM
garfull's Avatar
garfull
But that doesn't explain why the air conditioning must be on at the same time. I don't see why automatically sensing the air freshness and selecting fresh or recirc air requires the use of ac. I want it to auto select air but not ac.
Old Dec 13, 2009 | 08:47 AM
garfull's Avatar
garfull
Anyone can confirm that a/c is on when auto recirculation is on?
Old Dec 13, 2009 | 06:30 PM
DaRacerz's Avatar
DaRacerz
Well, I can't confirm your statement, but I wasn't recently at the dealer selecting the LPS and I remember there were settings for AC being auto on in a couple of different situations and it was possible to disable it. Defroster mode was one of them. Don't remember the rest. If I remember right, these were dealer only selectable options. You may want to ask your dealer if this can be modified.
Old May 5, 2011 | 11:09 AM
RA122022's Avatar
RA122022
Can someone clearly explain how to set and monitor "Automatic air intake change mode"?
The user manual is a little light on the topic.
Thanks.
Old May 5, 2011 | 01:48 PM
RXSF's Avatar
RXSF
to answer the OP, yes you have to have the AC compressor on, or if you keep pushing the recirculation button it will auto turn on the AC and you can turn on the auto function which is monitor the air coming into the cabin (smog, dust, pollen) and automatically close or open the vent to outside air
Old May 5, 2011 | 03:19 PM
larrs's Avatar
larrs
I'm not sure all models with nav have this function -- mine does not. The recirc button only has two lights, neither of which is auto.
Old May 5, 2011 | 06:06 PM
RXSF's Avatar
RXSF
it goes with the luxury package, not nav
Old May 5, 2011 | 06:08 PM
kitlz's Avatar
kitlz
No, I don't play soccer!
RXSF, do you have a picture?
Old May 5, 2011 | 10:03 PM
RXSF's Avatar
RXSF
will do this weekend
Old May 6, 2011 | 09:15 AM
zak21's Avatar
zak21
CL Folding 500,000
It also came with early 2010 models as well along with the sunglasses holder
I love this feature in ours along with the auto climate with AC. From my experience and research the AC compressor is a design that doesn't use a clutch like most standard compressors to turn the AC on/off. It uses a swash plate to vary the output from virtually 0 to 100% based on demand and driving conditions and is very efficient. Also since there is not a clutch the compressor is running when the engine is. I have noticed no change in mpgs during my testing with the ac of vs auto mode so I leave it on auto all the time and enjoy the comfort.
So don't be afraid to use the AC...
That's my two cents anyway.
Old May 7, 2011 | 12:29 AM
RXSF's Avatar
RXSF
Not sure what you were expecting Anita, but its literally just an additional "auto" written on the recirculation button
Old May 7, 2011 | 03:58 AM
kitlz's Avatar
kitlz
RXSF, thanks. Mine looks similar with the auto button on the far left. I wanted to make sure I wasn't missing something
Old May 7, 2011 | 11:41 AM
RXSF's Avatar
RXSF
Oh we have that auto on the far left too. there are two autos. this one just controls the recirculation. For some reason, the AC has to be on before it will detect outside smog and close the opening
datpimp007
NX - 1st Gen (2015-2021)
Aug 16, 2016 11:03 AM
RLM
RX - 4th Gen (2016-2022)
Jun 23, 2016 12:49 PM
dougm213
Jun 24, 2014 06:34 AM
I8ABMR
IS F (2008-2014)
May 29, 2014 12:09 AM
Aleagle
Apr 9, 2012 08:28 PM
