Unable to start help with Diagnosing
Old Jan 19, 2025 | 04:58 AM
Jerseyguy9123's Avatar
Jerseyguy9123
5th Gear
Angry Unable to start help with Diagnosing
Hello, I'm a new member of the forum. Thank you in advance for your suggestions.
I have a 2012 RX 250, 210k miles on it. was driving it for 30 minutes prior to this happening. Stopped at a store to get something and when I get back into it and press the push to start, all of the lights come on but the starter does not engage.
There was a message about the battery for the key fob being low a day or so ago. I replace the battery, no help.
The light on the push to start button turns from yellow to green when I am in the car and even when I put the fob next to the button.
The brake lights come on when I depress the pedal. I have disconnected the battery for 5 minutes to try to reset the system. No help.
Trying to diagnose before I tow it to a mechanic.
Thanks in advance for your thoughts
Old Jan 19, 2025 | 05:08 AM
RX in NC's Avatar
RX in NC
How old is your battery? Have you measured its voltage?
Old Jan 19, 2025 | 05:33 AM
Clutchless's Avatar
Clutchless
I agree, it is hopefully and likely just a worn out battery that was killed by this recent extreme cold weather. Buy a new battery before taking it to the shop.
Old Jan 19, 2025 | 06:15 AM
Jerseyguy9123
5th Gear
Interesting point, I have not checked the battery. Will do so.
Though, it does not make sense that there would not at least be an attempt to engage the starter.
No clicking, no relay, nothing. and no dimming of the dashboard lights.
To me, it would seem those would be some of the signs that the battery is weak.
I won't be able to have the battery tested under load because of where the car is.
Thoughts on other things to look at?
Old Jan 19, 2025 | 09:32 AM
salimshah's Avatar
salimshah
25 Year Member
Battery is the source but there are safety interlocks like, brake pedal switch [have some one stand behind and make sure the brake lights light up when pedal is depressed], the gear shift level needs to be in P or N. [just shove the shifter into Park], and finally the immobilizer [right key fob needs to be inside, close to the starting switch, with no interference].
So start with the easiest and most common the battery if it has not been replaced in 4+ yrs. Voltmeter can mislead as it measure voltage without load. A load testing is more conclusive.
Salim
Old Jan 19, 2025 | 09:37 AM
Jerseyguy9123
5th Gear
Salim
good suggestions, battery is exactly 3 yrs old. I’ve check through all of them, battery is at 12.05 without things turned on, drops to 11.85 with just the dash on. Drops to 11.60 when I depress the push to start button. Will try a jumpstart before fiddling with anything else.
Old Jan 19, 2025 | 10:14 AM
RX in NC's Avatar
RX in NC
With those voltage measurements, your battery is stone dead. You can try to charge it, but I would replace it. How much of your battery warranty remains? Be sure to take advantage of it.
Old Jan 21, 2025 | 05:52 PM
Jerseyguy9123
5th Gear
Resolved...
Thank you for the suggestions.
Towed to a mechanic and he replaced the starter and the battery.
Thanks again for your suggestions!!!!
Old Jan 21, 2025 | 08:37 PM
intermec's Avatar
intermec
why the starter?
did the shop just put a local auto part store starter?
Old Jan 22, 2025 | 05:01 AM
Jerseyguy9123
5th Gear
Originally Posted by intermec
why the starter?
good questions, I did not think to ask before authorizing the work.
the bill shows a remanufactured starter.
makes me feel taken advantage of.
Old Jan 22, 2025 | 05:16 AM
RX in NC's Avatar
RX in NC
It is very likely that all you needed was a new battery. I would battle with that "mechanic" regarding why he felt the need to replace the starter.
Old Feb 1, 2025 | 07:10 PM
Riickk's Avatar
Riickk
==> ...battery is at 12.05 without things turned on, drops to 11.85 with just the dash on. Drops to 11.60 when I depress the push to start button.
Not horrible, but yes, low. Will bet that the battery cables have some corrosion, and resistance there dropping voltage = No Start.
Old Feb 2, 2025 | 05:49 AM
RX in NC's Avatar
RX in NC
That battery is shot.
Wicked3UZ
Aug 29, 2023 04:02 PM
LexBob123
Jan 9, 2023 12:49 PM
esonu
Jun 25, 2020 10:59 AM
jarm
Feb 18, 2013 03:21 PM
wboro4
Jun 19, 2010 06:30 AM
