Help: Car Won't Start
Old Jun 18, 2010 | 07:39 PM
wboro4's Avatar
wboro4
Default Help: Car Won't Start
As the topic states, car will not start. Radio, power, etc all that works but i only get the red light on the push button and the starter won't even click. I did disconnect the battery earlier and i know i thought i read something where the key has to be paired back with the car again after the battery is disconnected? Any help would be greatly appreciated. It is an 08 IS250 awd.
Old Jun 18, 2010 | 07:52 PM
ldc's Avatar
ldc
Do u think your remote battery is going?
Old Jun 18, 2010 | 07:58 PM
VIS250P's Avatar
VIS250P
The car battery is weaker and go replace new battery unless if they cover on warranty
Old Jun 18, 2010 | 10:42 PM
Bichon's Avatar
Bichon
Are you depressing the brake pedal far enough? The starter button light should change from orange to green when you do.
Old Jun 19, 2010 | 06:30 AM
9relude8's Avatar
9relude8
most likely your KEY FOB's battery is dead so the button will not turn green since it does not detect it. Have you ever changed the KEY FOB's battery? Did you see a warning message that the KEY FOB's battery is low on your dash?
One other thing you can try is an emergency start. You must place your key against the button and push for a emergency start up. Check your owners manual and look for a detailed procedure. Good luck
yeehawbob
RX - 3rd Gen (2010-2015)
Sep 8, 2018 03:38 AM
dogbitdude
Mar 26, 2018 08:02 AM
nks979
IS F (2008-2014)
30
Jan 13, 2016 11:58 PM
tofu
Apr 25, 2014 09:20 PM
FinsIS250
Oct 3, 2012 09:18 AM
