Keep it going
Old Jul 8, 2024 | 06:20 AM
sunnyside's Avatar
sunnyside
Default Keep it going
My 2014 RX 350 is sitting at 96,000. I know it needs some routine upkeep to keep my ride going for the next 100,000. What should be done at this point and what should it cost?
Old Jul 8, 2024 | 08:02 AM
RX in NC's Avatar
RX in NC
Have you done the series of multiple ATF drain-and-fills in order to refresh the required lubrication qualities of your transmission fluid? These Aisin transmissions are mediocre at best and it is wise to do that at least every 50,000 to 60,000 miles.
With a few proper tools this is an easy DIY project. There are several threads here on the forum that will take you step-by-step through the process.
Old Jul 8, 2024 | 11:22 AM
Clutchless's Avatar
Clutchless
As recommended above do a series of cold transmission drain and fills, or pay an independent shop to do it. It is not difficult. Then see the thread below for more maintenance information.
https://www.clublexus.com/forums/rx-...vice-list.html
and this one for the transmission info:https://www.clublexus.com/forums/rx-...d-threads.html
Old Jul 8, 2024 | 11:23 AM
salimshah's Avatar
salimshah
25 Year Member
Minimum and manufacturer's suggested items are listed in the Warranty and service booklet [thinnest manual]. Look at your current milage and scan back and catch up on the unperformed service items.
RX in NC has good additional item which may be found under fine print under extreme operating conditions. Please search on this service item [a well discussed item]
Salim
LexNYC83
RX - 5th Gen (2023-present)
20
Jan 23, 2025 10:22 AM
jwong77
Dec 7, 2022 12:35 PM
xjokerz
RX - 3rd Gen (2010-2015)
Aug 15, 2021 08:37 AM
GRPFAN
May 31, 2015 06:48 PM
