Wanting 2010 - 2012 Rx350 AWD
Old Jul 4, 2023 | 12:16 AM
carguy75's Avatar
carguy75
Originally Posted by lyndell2012
Well folks, i appreciate the wealth of information. Before this, I had not looked at the 2013 though I do like the new look. The price difference between 2012 and 2013 is not that prohibitive. And there seems to be some interesting color choices in 2013 that I have not seen before. I will take my leave and wish everyone a good week.
Good luck on your search.
My advice would be to really perform a proper check for any leaks on your prospective used RX350 that you are planning on purchasing. The main points of concern for a 2013 and newer RX350 AWD would be a transfer-case cover leak(rare, but happens with age) and front timing cover leak(very common); since both would require an engine removal to fix that is expensive. The 2010-2012 AWD main concerns would be the cover(timing and transfer-case) leaks like the 2013 and newer models as well as the rubber oil cooler and VVT hoses.
The water pump is also a common failure point for any high mileage(over 80k miles) RX350 from 2010-2015 that should be checked, but not too expensive to repair.
taleh
RX - 3rd Gen (2010-2015)
48
May 13, 2024 08:11 AM
wgregt
17
Feb 2, 2023 10:19 AM
Dobiexx
Jun 3, 2021 05:15 PM
stefnee
Feb 18, 2013 11:33 AM
waynedog
Dec 16, 2012 10:55 AM
