07 RX350 Clock Issue
Old May 19, 2020 | 10:29 AM
Calk's Avatar
Calk
Default 07 RX350 Clock Issue
Hello, I recently purchased a 2007 RX350 and the clock it stuck at 6:00. It never changes other than flashing sometimes after start up. I have gone into the info section and attempted to adjust it but it won't change. Am I missing something here or should I be attempting to adjust it differently? I appreciate any help I could get on this. Thanks!
Old May 19, 2020 | 11:58 AM
JapaneseBo's Avatar
JapaneseBo
You must be doing something wrong, I also recently purchased an 07 350, and the clock is fine. It is a slightly fiddley system, but easy enough to change the clock. Get someobe else to cast their eye over it, fresh pair of eyes maybe...
QUOTE=Calk;10807238]Hello, I recently purchased a 2007 RX350 and the clock it stuck at 6:00. It never changes other than flashing sometimes after start up. I have gone into the info section and attempted to adjust it but it won't change. Am I missing something here or should I be attempting to adjust it differently? I appreciate any help I could get on this. Thanks![/QUOTE]
Old May 19, 2020 | 12:29 PM
Calk's Avatar
Calk
That's kind of my point by posting this. To maybe have some others input. How did you change your clock?
Thanks!
Old May 19, 2020 | 02:33 PM
Lexuswiz's Avatar
Lexuswiz
Do you have the auto time zone and auto clock adjust on? If so, turn those off and see if a manual change will work. If that does not work, the digit display maybe going bad and may need a swap.
Old May 19, 2020 | 09:36 PM
Calk's Avatar
Calk
Yes, and no. I have tried every possible combination of on/off with the time zone and auto adjust. The clock did change from 6:00 to 7:00 when I switched the daylight savings time adjust on and off. It reads like this 6 00 normally but when I attempt to set it, it then reads like this 6:00 with the colon between the h:mm. It will never change though, to say 6:01 or anything. I sat there for 10 minutes waiting and nothing. So, now to determine if the problem is in the nav unit or the actual clock readout. It did change from 6 to 7 so it seems like the display is working fine, it's just the communication between the nav unit and the clock that doesn't appear to be working properly.
Thanks for your help!
Old May 20, 2020 | 08:22 AM
matts6887's Avatar
matts6887
like one of the others mentioned; its probably the clock display itself going bad? is yours with or w out navigation? if its w nav; normally the clock is always accurate as its set by gps; but if if it wont change at all then yea its most likely the clock mechanism itself has gone bad.
Old May 20, 2020 | 05:01 PM
Lexuswiz's Avatar
Lexuswiz
Ah, I was worried you were headed down this path. Unfortunately unlike Toyota's this is a two part system as you noticed. I do believe also that your display is probably ok but I still scratch my head on why it has to be controlled by the touchscreen.
Maybe try a full power discharge by disconnecting the battery for at least and hour. If that doesn't work the display is probably the next cheapest thing to try, a few used on ebay or similiar.
Old May 27, 2020 | 06:01 PM
Felix's Avatar
Felix
I set the clock in our rx w/ the gps off, so I can set the clock a couple minutes ahead.
RX350OK55
Aug 18, 2019 02:56 PM
ogee2142
Jul 25, 2017 12:18 PM
ricardo304
Feb 13, 2016 02:51 PM
KRW317
May 31, 2013 08:13 AM
jinnjia
Sep 4, 2007 08:15 PM
