HID Replacement Bulb Help
Old Jan 28, 2018 | 09:30 PM
Kishanptl1's Avatar
Kishanptl1
Default HID Replacement Bulb Help
I am noticing my 2nd generation RX HID low beans are not very bright. I have been doing some research on what typre of bulb I can replace them with... Are the oem xenon? Also any recommendations. I would like to have the brightest bulbs, that are plug n play. I have tried convertion kits, but no luck
Old Jan 30, 2018 | 03:56 PM
Lexuswiz's Avatar
Lexuswiz
How long have you had your RX and is this your first time working with HID cars? I have to ask because for city driving, HID's are usually washed out by the street lights and may seem dim unlike halogen and LED which punch through better. But in the country, HID's excel.
At the same time, if you are on your original bulbs, they do get slightly dim over time but it's not significant like halogens. I usually recommend 4300K bulbs by Philips or Osram as that gives the maximum light output and is factory spec but unfortunately is white with a yellow hue to it. My next set will be Osram 6000K bulbs for an ice-white look which I'm willing to take the hit on light output for color as my RX really only gets city driving anyways.
Old Jan 30, 2018 | 04:16 PM
Kishanptl1's Avatar
Kishanptl1
I bought an 2010 LS 460L back in 2011, but I let the dealer do all the work on that car. My experience is more towards the halogen side because I used to own a 2003 ES 300 before I traded up to this RX. The big reason I would like to upgrade is because the HIDs in the LS are great for city/country road, however these RX HID's light output is terrible compared to my LS. I know that I cant really compare them, but I might just by the HID light replacement like you suggested. Also I have owned this 131000 mile RX for two months, and I don't have any previous service records from the previous owner.
Old Jan 30, 2018 | 04:44 PM
Lexuswiz's Avatar
Lexuswiz
A bulb upgrade will probably help especially if you change the kelvin to something cooler like 5000-6000K which punches deeper at the cost of overall brightness. Also you are right, the LS is incomparable, I have driven a 2006 LS430 and also know what is used for the HID components and our RX comes nowhere near. Too bad the projectors wouldn't fit in my Camry's housing without significant mods otherwise I would have used the LS over the MDX.
Old Jan 30, 2018 | 05:08 PM
Kishanptl1's Avatar
Kishanptl1
Yea I might have to do that... but I think my HIDs are just aged. I might need to call lexus dealer and see if they might give me a complete history of the services performed by the previous owner. For HIDs they should not be this dim in in my RX.
NEWONE1
Feb 21, 2018 03:05 PM
08wis250
Oct 29, 2014 11:28 PM
jimjaix
Jun 13, 2013 10:02 PM
YoshRX300
RX - 1st Gen (1999-2003)
Apr 30, 2007 03:39 PM
whitels
Lighting
16
May 8, 2002 12:46 AM
