update navigation disks
Mine worked first try, just put it in the drive and turned on the car, changed the area and we were up and running. Maybe your seller didn't create the disc properly or it's damaged. I got mine from this seller...
https://www.ebay.com/itm/Newest-2016...72.m2749.l2649
I wonder if the Gen5 maps still works on Gen4 machines like they used to.
I used to run Gen5 14.1 on my Gen4 machine, no issues.
Gen5's final version is 2016, where Gen4 is 2015....
the gps disk goes in ther rear cargo area. To the right of the jack there is a 6x2 inch plastic cover. Remove the cover. Turn the car on. Push the black switch on the DVD behind the cover. It's top left facing the DVD. When you slide the switch left. It will eject the old disk. Push the new one in like it's a regular DVD player. Slide the switch back. The nav should start to install automatically. DO NOT TURN THE CAR OFF TILL ITS FINISHED. Hope this helps.
Most of the eBay listings for 2016.1/U41 offer disks marked "East" or "West" although a few listings show disks labeled without either regional split. Is there a disk version combining both East and West? FYI my RX 350 is a 2008, so I'd be shopping for a Gen 5, per earlier helpful post:
I have bought a few from ebay and they work fine. What year is your RX? Lexus has stopped producing updates for the older systems.
2015.1/U30 is the latest update available for the gen 4 and was released in the fall of 2015
2016.1/U41 may be the last available for the gen 5 and was released the fall of 2016.
2017.1/U99 just came out for gen 6 in the fall of 2017 but not anything older.
Generation 4
2005-2006 RX330
2006 RX400h
Generation 5 Navigation
2007-2009 RX350
2007-2009 RX400h
Generation 4
2005-2006 RX330
2006 RX400h
2007-2009 RX350
2007-2009 RX400h
prowler97
Hybrid Technology
Sep 7, 2010 01:54 PM
