hill assistant
Old Dec 12, 2017 | 10:49 PM
arsm's Avatar
arsm
Default hill assistant
Is anyone having experience as if RX 350 2007, safe to drive while coming down a deep hill?
Old Dec 13, 2017 | 03:07 AM
DennisMik's Avatar
DennisMik
I've driven up and then down Pike's Peak in Colorado (14,000 plus feet) in my 2007 RX. Car did just fine. You will be using the brakes a lot, so make sure the brakes are in good condition.
Old Dec 14, 2017 | 11:36 AM
tomr51's Avatar
tomr51
use the low gears to save on brakes
Old Dec 14, 2017 | 11:38 PM
DennisMik's Avatar
DennisMik
Going down a steep mountain requires a combination of gears and brakes. There were some areas where I was in 2nd gear and I had to use the brakes to keep the rpms under 6K. When you use the engine for braking, it will use more oil, so every day mountain driving requires frequent checking of the oil level.
Old Dec 15, 2017 | 01:37 AM
tomr51's Avatar
tomr51
how does it use more oil?
Old Dec 15, 2017 | 03:39 AM
05RX330AWD's Avatar
05RX330AWD
More stress on the engine therefore possibly some more oil consumption, best to check the transmission fluid also for a drain & fill if towing or mountain driving on a regular basis.
Old Dec 15, 2017 | 07:27 PM
DennisMik's Avatar
DennisMik
When using the engine to slow the car down, oil is "sucked" past the piston rings because of high vacuum in the cylinders. This happens because you have your foot off of the gas pedal, which means the throttle valve is closed. When the piston goes down on the intake stroke, it can't draw in any air/fuel mixture which is the cause of the high vacuum. As the engine gets more miles on it, the more wear and tear is on the engine piston rings and cylinder wall, the more oil will be sucked up. It is not going to be large amounts of oil, but if you constantly use the engine for braking every day, you will see the oil level go down over time.
Old Dec 16, 2017 | 06:00 AM
arsm's Avatar
arsm
Many thanks to all of you for your advice and valuable information. Yes i came down of the hill using lower gear shifting between 1 & 2 with less braking. It took me almost 45 minutes from a deep hill with 35KM
Regards
HanaleiISF
Dec 5, 2014 03:47 PM
Stormforge
Jan 6, 2010 12:38 PM
sammy5001
Apr 6, 2008 11:27 AM
RON430
Maintenance
Feb 26, 2006 08:13 AM
