Brake Dragging after Pads Replacement
Old Aug 12, 2017 | 08:43 AM
tadiguy's Avatar
tadiguy
Default Brake Dragging after Pads Replacement
My rear right brake is dragging after I replaced the pads. Initially, I thought it was a defect pad and so I returned it and got a different one/brand, but it still drags on the same side.
  • When I put the old worn pads back on everything seems fine.
  • Caliper piston glides back nicely and smoothly when I compressed it to install new pads
  • I cracked open the bleeder valve to bleed the brake so I'm sure I din't push any contaminants back into the system.
  • I lubed caliper pins like I always do. They move freely when inserted.
  • I checked and adjusted parking brakes to ensure the rotor spins freely, but as soon as I install wheel lugs it seizes again (in fact, it binds if I only install the lugs nuts without the wheel)
  • Brake fluid shoots out OK when brake pedal is depressed and there is no sign of pressure lock when I release the brake.
Any thoughts about what could be binding? It must be mechanical interference because when this happened with the first set of pads I heard whoob-whoob-whoop sound as I took it for a test drive. I can't hear a distinctive sound now, but it still binds and heats up.
Old Aug 12, 2017 | 02:08 PM
BlackLexRX's Avatar
BlackLexRX
Warped rotor?
Old Aug 13, 2017 | 03:45 AM
tadiguy's Avatar
tadiguy
I swapped rotors and the problem stayed on the same side, but that gave me a moment to pause and rethink what else it could be. It turned out to be the lower caliper pin - the rubber bushing at the tip of the pin was a little deformed and binding.
10lexISR6
RC - 1st Gen (2015-present)
Jun 25, 2018 08:46 PM
ChocosLS430
Nov 7, 2016 05:46 AM
UberNoob
Suspension and Brakes
17
Sep 18, 2009 08:39 PM
Rit&Booner
25
Nov 7, 2007 07:23 AM
Little_D
Feb 5, 2005 11:24 PM
