Rear Emblems
Old May 7, 2003 | 02:20 PM
CK6Speed's Avatar
CK6Speed
Default Rear Emblems
Anyone know if the rear Lexus and RX 330 emblems have any kind of guide pins behind them? I'm thinking of removing them for a cleaner look. Over the years I've also found that it makes waxing and polishing much easier. Thanks.
Old May 7, 2003 | 02:37 PM
j4ydubs's Avatar
j4ydubs
Default Re: Rear Emblems
They're probably applied the same way they are on the GX - with adhesive and no guide pins. Here's a link to a thread where someone removed the badges on his GX.
John
Old May 8, 2003 | 06:23 AM
Marco-Polo's Avatar
Marco-Polo
The Lexus RX300 signs are only glued.... but careful, once taken off you can put them back, they will most likely brake or bend once taken off. You will need to buy a new set, which doesn’t come cheap!!!
And to remove the old glue left on the boned is another story…
The Emblem (L) got 4 small pin’s (rubber) you can very carefully remove the Emblem and putting it back… but again…it wouldn’t do any good to take it off and on all the times….
regards
M
Old May 8, 2003 | 08:38 AM
rogerh00's Avatar
rogerh00
Veteran: Air Force
The L emblem on the back of my '01 rx300 has two plastic pins . I'm holding it my hand because I mistakingly replaced the chrome one with a gold one. The gold finish weathered badly and when I tried to polish it the gold came off. At the moment I have a two tone emblem until I pull it off.
Old May 8, 2003 | 02:53 PM
CK6Speed's Avatar
CK6Speed
Thanks. I plan on leaving the center L emblem and will just remove the Lexus and RX 330 on the left and right sides. I'll try it today or maybe over the weekend.
Old May 8, 2003 | 05:04 PM
Marco-Polo's Avatar
Marco-Polo
CK6speed
Should not be any problem, to remove the glue you should rub it off with your finger nail and using some thinner to remove the stain on the boned.
Good luck man and enjoy your ride
marcus - Kuala Lumpur / Malaysia
To replace the (L) emblem from chrom - to - Gold ....
You could visit
http://www.lexus-parts.com/
to purchase a new gold emblem, they will give you warranty on the part!!!
best regrads
marcus
Old May 8, 2003 | 11:39 PM
CK6Speed's Avatar
CK6Speed
Originally posted by Marco-Polo
CK6speed
marcus
Yes, I removed the LEXUS on the left side and the RX 330 on the right side in about 3 minutes. It took me about 2 minutes to pull off the adhesive left behind. The good thing is that because the car is still new, the adhesive didn't have time to really bond so it practically pulled right off. A quick wax and you can't tell there were any emblems there at all. Total time was a little over 5 minutes including the wax
Old May 9, 2003 | 01:41 AM
Marco-Polo's Avatar
Marco-Polo
great i am happy for you.... stay in touch.
best regards
marcus
rs/ss
GX - 2nd Gen (2010-2023)
Apr 7, 2012 03:22 PM
debosteebo
Jul 3, 2006 11:42 AM
YaYAReAGs3
Sep 22, 2004 10:14 AM
Philly#1 Lex
RX - 1st Gen (1999-2003)
Apr 15, 2004 10:15 AM
chrisgs
Apr 29, 2003 05:45 AM
