Chirping noise....
Old Jan 5, 2015 | 06:33 PM
snydertalo's Avatar
snydertalo
Default Chirping noise....
So from reading around a lot, it seems like the chirping is from the belt tensioner or idler pulley. That said, I've not been able to find anything definitive. I tried to do the water bottle squirt test (from Gates' youtube video) and either I did it wrong or the chirp did not go away implying the issue is not the belt. While I was looking in, I could see the tensioner shaking some.
Would someone be able to look at theirs and see if there is any play?
If my tensioner should not be moving, do I just need the pulley or the pulley and the mount?
- Pulley | https://www.rockauto.com/catalog/x,c...,parttype,6956
- Pulley and mount | https://www.rockauto.com/catalog/x,c...parttype,11659
Also, if the above items will fix the chirp, which brand would be best? I know cost != reliability, but you also get what you pay for.
TIA.
2007 RX 350, 113K
Chirping gets worse as it heats up
Seems to happen independent of ambient temperature
Purchased a year ago so unsure of the history of part changes.
Old Jan 5, 2015 | 07:30 PM
LazarusLng's Avatar
LazarusLng
Can you post a video of the chirp in question?
Old Jan 5, 2015 | 08:58 PM
snydertalo's Avatar
snydertalo
Here's a video:
From this image (http://lexus.sewellparts.com/images/...000/162578.jpg) it looks like the IP is really stable. I couldn't get a good shot of it but the bolt head in the middle does not move at all. The TP seems to move a lot, but I don't know if that's normal or not.
Old Jan 6, 2015 | 09:26 AM
beefmc's Avatar
beefmc
I had a chirp that ended up being the water pump
Old Jan 6, 2015 | 11:37 AM
RXPhil's Avatar
RXPhil
I had an annoying chirping sound as well that still haunts me. Turned out to be a pulley.
Old Jan 7, 2015 | 05:10 AM
LazarusLng's Avatar
LazarusLng
Just this morning I noticed a chirp, right as I started her up. Just one chirp. It is cold out, about 8 degrees.
Old Jan 7, 2015 | 10:24 AM
snydertalo's Avatar
snydertalo
How did you guys identify which pulley it was?
Old Jan 9, 2015 | 12:10 PM
beefmc's Avatar
beefmc
I took mine to my indie hoping it was just the serpentine belt...no luck. he saw my water pump was dripping on the belt, thus producing the sound I was hearing. 600 dollars later....
Old Jan 9, 2015 | 12:18 PM
robbyk's Avatar
robbyk
I had a similar chirp, the tensioner was the culprit.
The easiest way to trouble shoot this issue is with one of these:
http://www.harborfreight.com/mechani...ope-69913.html
On sale for limited time.
This works great for tracking down bad pulleys, various engine noises, and bearing issues. It clamps down into my ears very tightly, and will hang from my head without slipping out.
It amplifies sounds VERY well. Touching it to a bad alternator or power steering pump will "pump" the sound of failure right into your head, so you know exactly what to replace without guessing.
tokio417
Jul 30, 2017 06:40 PM
lexuspaaji
Oct 11, 2016 01:57 PM
dtLS400
May 24, 2013 10:54 AM
JayCaz
Apr 4, 2011 06:13 PM
lexlyf
Jul 4, 2001 02:17 PM
