Engine Warning Light P0500
Old Jan 11, 2014 | 04:41 PM
mweeks10's Avatar
mweeks10
Default Engine Warning Light P0500
My Check engine light comes on frequently. The corresponding code is P0500. Can anyone provide advice on how to replace the Speed Sensor?
Old Jan 11, 2014 | 06:06 PM
HtownBlue's Avatar
HtownBlue
Front speed sensor is actually pretty easy. Take off wheel. 10 mm bolt on inner part of steering knuckle where the axle runs through it. Take out bolt. Remove other bolt attached to wire up near strut. Remove from where it attaches to clip. Replace. You do have to reach under the week well plastic to find where it clips to the rest of the wire.
Old Jan 13, 2014 | 07:37 AM
mweeks10's Avatar
mweeks10
Thanks for the information. Which wheel are you referring to? Steering wheel or tire wheel? Do you know where I can find printed instructions?
Old Jan 13, 2014 | 08:14 AM
sweet100's Avatar
sweet100
it is tire wheel
Also note that 'easy' is very subjective, especially if HtownBlue said so. He is MUCH MORE experienced than you and me.
Old Jan 13, 2014 | 11:39 AM
HtownBlue's Avatar
HtownBlue
Alldatadiy.com has lots of information for a small fee and might have some instructions.
There are two 10mm bolts to remove along with the wire harness clip where it joins the rest of the wire that feeds to ABS/ECU.
khizr23
Jan 7, 2019 02:04 PM
BigGeigs
Jul 12, 2012 08:20 PM
93lexgs3
GS - 1st Gen (1993-1997)
Mar 8, 2011 05:20 PM
Hennesssy
Suspension and Brakes
15
Jan 24, 2009 06:11 PM
Brandon714
IS - 1st Gen (2001-2005)
Sep 19, 2006 07:29 PM
