IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
HELP: Wire got pulled
Old Sep 18, 2006 | 11:51 AM
Brandon714's Avatar
Brandon714
Default HELP: Wire got pulled
I was on the freeway got a blowout on the pass rear tire and somehow someway the rubber caught this wire and pulled it. The ABS and Brake system warning light is lit and the TRAC light is blinking.
This wire goes from the brakes to inside the wheel well to a harness somewhere... I tried to get to it from the trunk but cant seem to find it. Does anyone know how to get to the harness so I can solve this little problem?
Thanks
Old Sep 18, 2006 | 07:16 PM
Tammy's Avatar
Tammy
This is the ABS wheel speed sensor. I might be ruined.
As you suggested, the plug should be within a foot of the access hole in the trunk.
Shine a flashlight in the hole and look for light inside the trunk. Or fish in the hole a coat hanger wire and rattle it around, looking for the access.
Old Sep 19, 2006 | 06:23 PM
Brandon714's Avatar
Brandon714
Yup that's what it was...
I found the harness by taking the back seat out. I reconnected the wires but the ABS and Brake warning lights are still on TRAC light is still blinking... I reset my ECU thinking that will fix it but no go...
Is there something that need to be reset or should I just take it to dealer?
Thanks guys!
Old Sep 19, 2006 | 06:51 PM
Tammy's Avatar
Tammy
More than likely, the speed sensor needs to be replaced.
An independent should be able to handle it, or the dealer for sure.
Old Sep 19, 2006 | 07:29 PM
Brandon714's Avatar
Brandon714
I decided to go for a drive.... After about a min or two all the lights turned off and braking was back to normal...
Problem solved...Thanks for your help!
Ls460kidd
Jan 24, 2019 09:34 AM
Mv350
Sep 18, 2009 09:56 AM
John U
Jul 7, 2008 06:13 PM
THE_CEO
Nov 21, 2002 08:18 PM
