Beatsonic harness vs. Alternatives?
Old 07-24-17, 06:13 AM
  #106
cfcubed
cfcubed's Avatar
Default 1/8 or 1/4 watt should work fine
Originally Posted by Cruz77321
<snip> Metra Dash kit comes with a 68 OHM resistor to get the climate controls to work. I would like to order this resistor separately but need to know the wattage of the resistor to order. Does anyone know the wattage of the resistor to install in order to get the climate controls to work? Thanks
The supplied resistor was tiny so probably an 1/8 or 1/4 watt. Any wattage would likely work as it seems its at comm level (TX-, TX+ ?).
I've two spares & as you're in US if you drop me a PM I'd mail one out to you no cost. Tiny pay it forward as this forum really helped me w/my install.
Again I took a shortcut & just cut the leads short on the resistor & press fit the leads into the OEM 12-pin connector & wrapped w/a bit of tape + ziptie .
Last edited by cfcubed; 07-24-17 at 11:24 AM. Reason: value matters, wattage doesn't
Cruz77321 (07-28-17)
Old 03-23-18, 09:47 AM
  #107
AFZ
AFZ's Avatar
I need some help.
Installing a Stereo into a 2008 RX400H with ML and Navigation.
I have the Axxess TYTO-01 and Metra installation gear. Stereo works fine, I lose functionality of the upper display (A/C).
Metra says to install the resistor into the 10 and 9 pin Red and Black wires. The car does not have any such wires. #10 is Grey. #9 is Red and #8 is Black.
I tried both #10 and #9 and then #9 and #8, neither scenario brought back the A/C-Controls.
Old 12-03-18, 08:32 AM
  #108
RMVasilyev
RMVasilyev's Avatar
Hi, which Adax box u used? I tried metra aftermarket setup. Very bad sound on high volume.
I used the resistor on the contact which comes with 2 cables on my 2004 model
QUOTE=AFZ;10151101]I need some help.
I tried both #10 and #9 and then #9 and #8, neither scenario brought back the A/C-Controls.[/QUOTE]
Old 12-06-18, 03:27 PM
  #109
rexsio
rexsio's Avatar
you probobly need the AX-ADBOX1 in conjunction with the TYTO-01 and maybe the metra 70-8114 also. i'm not sure but the NAv units need more then just the TYTO-01. You can email Metra costumer support directly. also Don't know if this helps, but the Beat-sonic has a direct plug-n-play solution for Mark Levinson with Navigation for the 400h. i had a similar problem with pin 9 and pin 10 and was able to solve it with this unit , metra 70-8114.
Old 05-11-19, 02:38 PM
  #110
crosborne
crosborne's Avatar
Read through all of this. Went to Metraonline which led me to Axxessinterfaces. Searched for my vehicle.
2004 RX330, ML/Nav and steering wheel controls. It came back with just one part.
AX-TYAMP1-SWC
Anyone have experience with it? Is this really All I would need now?
Jerkey
IS - 1st Gen (2001-2005)
03-05-17 01:54 PM
sidwin
08-13-12 05:34 AM
jdog0411
04-11-11 01:11 AM
Extrudedco
02-03-11 02:16 PM
chb402
02-08-08 10:48 AM
Quick Reply: Beatsonic harness vs. Alternatives?
