climate control air temperature problem when idle
Old Dec 12, 2012 | 07:25 AM
leop1212's Avatar
leop1212
Default climate control air temperature problem when idle
I have a problem with Climate control on RX330 2005.
In the summer when AC is on it works perfect on high RPM when I am driving, however on IDLE I am getting warm air instead of the cold. The Speed of the blower stays the same regardless of RPM while air temperature is changing a lot. Now I do see same problem with heat.
When engine is idle I don’t get hot air just slightly warm and as soon as start driving and RPM going around 2k or above I am getting hot air again.
I would appreciate any suggestion.
Old Dec 12, 2012 | 11:07 AM
lexus114's Avatar
lexus114
Sounds like your pretty low on engine coolant. Or maybe the water pump is having some sort of a problem.
Old Dec 12, 2012 | 01:57 PM
satz's Avatar
satz
Have you tried running the AC on 'manual' mode? ie just select the fan speed. See if that fixes the problem, then you determine whether it's the AC control/sensor that's playing up, or whether it's something more mechanical like the AC compressor
cheers
S
Old Dec 13, 2012 | 05:26 AM
LEXRX04's Avatar
LEXRX04
how many miles are on the vehicle? any services done lately?
Old Dec 13, 2012 | 08:50 PM
HtownBlue's Avatar
HtownBlue
Leop1212- Youhave an issue with your cooling fans that bring air through the condensor which allows the gas to condense. I'd bet good money if you plugged in a fan and directed it to blow through your grill of the vehicle and turned it on, the A/C would blow just fine all day long.
I'd bet you good money that if you idle the vehicle, pop the hood, you will not see the cooling fans turning at idle. When the points go out on those motors, air blowing through the grille while in motion can "trigger the fans to move" thus starting the fan for a while, thus it can be intermitant when at idle after driving as the motors only stop when stuck on a bad point internally.
Check the cooling fan motors. Trust me. It is either the motor itself or the connection from the Fan ECU.
Old Dec 15, 2012 | 05:29 PM
leop1212's Avatar
leop1212
Low coolant may explain heating temperature problem while won' make sense for AC
Old Dec 15, 2012 | 05:31 PM
leop1212's Avatar
leop1212
110k
have no service done lately
Old Dec 16, 2012 | 12:32 PM
HtownBlue's Avatar
HtownBlue
Leop1212 - listen to what I wrote earlier if you want to solve the issue.
UncleRico
GX - 1st Gen (2003-2009)
Jun 21, 2019 04:26 PM
pmnuon79
Jan 5, 2017 08:37 PM
aeropartz
Dec 22, 2009 02:12 AM
cutecboy
Feb 9, 2008 09:14 AM
kensteele
May 31, 2006 06:22 PM
