rx330 starting/electrical problems. Please help
Old Jan 27, 2012 | 10:56 PM
japanbran's Avatar
japanbran
battery installed properly. we also tried to jump it so i do not think a different battery would matter since trying to jump it did nothing. i will go through thru fuses again. are there any to check besides under the dash and thru box in the motor bay
Old Jan 28, 2012 | 12:13 AM
salimshah's Avatar
salimshah
25 Year Member
I was not too clear in asking the question ,,, ,was the battery installed with terminals reversed for a brief time ... this causes some fuses to blow.
The headlight dimming a bit confirms if the starter is drawing current and it seems it is not.
Saliim
Old Jan 28, 2012 | 01:41 AM
japanbran's Avatar
japanbran
nope. the terminals never touched or reversed. Yea, headlights and gauge cluster lights are bright. key will unlock the doors, thats about it. I cant get the hatch open at all, windows dont work, seats dont work, radio, ac, power outlets.. nothing but the gauge cluster. is there maybe a main fuse or something that I dont know about?
Old Jan 28, 2012 | 03:03 PM
japanbran's Avatar
japanbran
PROBLEM IS FIXED!!!!!!!!!!!! CAR IS ON THE ROAD AGAIN.
SOLUTION
After spending all trying working on it I tested the + wire in the fuse box in the motor bay, It was only getting 1.68v to it instead of 12.00v. So i took the fuse box apart and followed the positive wire from the battery into the box. Where the wire bolts to the ALT fuse was very lose. I then picked up a new ALT fuse since I was already in there, replaced it and made sure the wire was tight. Put it all back together and tested it again. full 12.66v to the + wire in the fuse box! grabbed the key, went to start the car, and she started right up. Big thanks to everyone that tried to help!
Old Jan 28, 2012 | 07:12 PM
RX330inFL's Avatar
RX330inFL
Congrats. Am sure your folks are appreciative of all the work you put into this troubleshooting.
Old Apr 21, 2012 | 04:41 AM
bealrv's Avatar
bealrv
I have similiar problem to the one describe above, however, I have radio, lights and windows, everything else is the same. I've replaced battery(new) and starter twice in addition to relay. When I turn the key in the ignition I hear a low level humm, nothing else. A mechanic suggested it was the ignition switch connector that has gone bad?
Obviously when they replaced the starters the problem went away for awhile but they game back
Old Sep 23, 2012 | 08:14 AM
quantfutur's Avatar
quantfutur
Originally Posted by jamodeo
Even if there was interference from another source and the car couldn't read the security tag in the key, the car would attempt to "turn over" but you would just continuously hear the starter over and over because the fuel cut off is the only thing that stops when it doesn't sense the security part of the key... So you would hear some kind of attempt for the car to start, there just wouldn't be any fuel for it to actually start.
-Joe
I realize this is delayed and off-topic a bit but I am having a small problem with starting my RX330 '05. Car was in a fender bender a few weeks ago (right front light out; needed new fender - ruled 'not at fault'; car in front stopped dead in a rotary!)... When I got the car back I noticed that there is a slight hesitation before the engine catches. (I also just noticed that the wiper fluid canteen cannot be filled - all goes to the ground immediately - probably a tube not hooked back up. Or a large puncture?)
Is it possible that they unplugged something when replacing the right front light and bumper, so that the fuel injection is not working right? Maybe something loose?
Old Nov 9, 2014 | 03:27 PM
Taidaisher's Avatar
Taidaisher
I had this same problem.
The car died on my wife. The instrument panel was working but nothing else, no radio, windows, steering column, etc. We replaced the battery and had the same problem with the new battery.
Working through all the fuses & relays, I discover the main fuse, 140amp fuse link had gone bad. The fuse is bolted on the sides with an 8mm and a 10mm bolt. That was so much fun to replace.
Once I replaced the fuse, which is a factory only fuse, couldn't find it at any local auto parts stores or amazon, the car started. I have windows, steering column, radio, chair, etc. The only thing not working now is the navigation screen, which also controls the AC/Heat, and the back up camera.
Any suggestions? I've gone through the manual and have checked every fuse that has any reference to nav screen.
Old May 16, 2016 | 06:20 AM
jcwray's Avatar
jcwray
Originally Posted by salimshah
That is good information.
I would suggest look through the fuses in the engine compartment. Some of the fuses are bolted in (due to high current demand).
Did any one put in the new battery the wrong way? +/- swapped. or any bad experience giving/getting jump.
Salim
My neighbor replaced my battery for me and put it in backwards.. fixed fusible link and power comes on but starter just keep turning with key turned.. Will not start
Old May 16, 2016 | 07:14 AM
jcwray's Avatar
jcwray
Saved. My wife found my unbroken key and it worked like a charm..
Old Jul 19, 2017 | 08:31 PM
ttnguyen23's Avatar
ttnguyen23
Where is the fuse link in 2007 RX350?
Thanks
Old Apr 4, 2018 | 06:58 PM
te7708e's Avatar
te7708e
Default 2006 Lexus rx330
my 2006 lexus rx330 is having trouble starting. I went to advanced auto parts store to have battery, starter, and alternator checked and everything is working properly. However, the car still had its original battery and my mechanic said I needed to replace it because batteries should be replaced 3 to 4 years. I replace the battery a week ago and today car sat for 10 minutes and it would not start. I received a jump and car started... not sure what the problem is.. please help...
Old Jun 11, 2018 | 11:56 AM
Xenoclast's Avatar
Xenoclast
Default I believe I have the same problem with my RX330
SOLUTION
How the heck did you get to the ALT fuse? I can’t get the fuse box apart enough to get to it!
Thanks for any help.
Old Jun 21, 2021 | 08:10 AM
Brucecav's Avatar
Brucecav
I thnk I may have the same starting problem with my rx330.
Can you tell me which fuse is the one (ALT fuse) that was the problem? I took the fuse box cover off and not sure which is the alt fuse. A picture would be helpful too.
Thanks so much!
artiechin
Mar 1, 2023 12:35 PM
scalf1976
Jun 24, 2018 03:51 AM
ronalsk
Jan 2, 2012 08:36 PM
mleads
Sep 1, 2010 08:56 AM
chris_D
Dec 2, 2008 09:35 PM
