Some questions
Old 12-13-11, 03:07 PM
MrBruin09
MrBruin09's Avatar
Originally Posted by jfelbab
Not necessarily. I'd only be concerned that these speakers are usually matched and replacing just one of a matched set might not deliver the best sound quality, especially if it is a different brand or model.
Much depends on how picky you are about the audio quality. In a moving vehicle the sound quality may not be all that significant anyway.
As to the failure, it could be due to several things; Water damage, electrical malfunction, loose solder joint, torn cone, manufacturer defect, etc. I'd not really expect the same damage to occur to the other speaker.
Thanks, The only reason I brought up this question was because the stereo guy I took to, told me the left speaker was starting to go out also, but I couldn't tell when I listened to it...So I don't know if it is true, or just him trying to make me purchase the speakers as a set.
Old 12-13-11, 08:55 PM
JoeInHNL
JoeInHNL's Avatar
Originally Posted by adam8065
Does anyone know if one side of your speaker goes out, does that usually mean the other side will go out as well?
I only had one fail and I just replaced that one. That was about 2 years ago.
I cannot tell the difference between the Vifa and the ML speaker
Old 12-13-11, 09:36 PM
MrBruin09
MrBruin09's Avatar
Thanks Joe, I will just purchase 1 ML speaker. I was going to buy the Vifa speaker, but it seems like it is discontinued, and the only speaker that is comparable to it is around $120 dollars, for that price I might as well get the ML speaker.
Old 12-14-11, 09:04 AM
MrBruin09
MrBruin09's Avatar
I have a stupid question to ask. How do I know if I have heated mirrors, and do all Rx mirrors come with memory settings?
Old 12-14-11, 10:05 AM
MrBruin09
MrBruin09's Avatar
Anyone know the answer to this?
Old 12-14-11, 10:22 AM
RX330inFL
RX330inFL's Avatar
Here are two features attributed to the outside mirrors in the current 2012 brochure:
Electrochromic (auto-dimming) outside mirrors
Power-adjustable outside mirrors with integrated turn indicators and defoggers
Each was considered standard under Active Safety. So, if you have a brochure for your vehicle I would look under that topic. If I had to guess I would say that yours are not heated, rather, they are electrochromic and will defog -- but are not heated per se.
Old 12-14-11, 10:35 AM
MrBruin09
MrBruin09's Avatar
Thanks, I believe they are not heated either, if I purchase one that is heated, would that have any pop up some adverse code or anything? And Is there a way to find out if my mirror has memory on it?
Old 12-15-11, 10:30 AM
MrBruin09
MrBruin09's Avatar
Does anyone know how to fix the automatic headlight leveling system? My warning light came on.
Also what kind of bulbs go in the center console, radio, etc?
Thanks
foreste1
09-26-18 02:48 PM
bigsherv
05-15-18 01:36 PM
PersianOne
12-29-15 10:56 AM
GavinTyler
RX - 3rd Gen (2010-2015)
06-20-11 07:06 PM
habsa56
SC- 1st Gen (1992-2000)
05-04-10 02:11 AM
Quick Reply: Some questions
