Main Req Light
Old Jan 4, 2011 | 07:32 AM
Tomcio78's Avatar
Tomcio78
Default Main Req Light
Does anyone know how to turn off the Main. Req. light on a 2004 Lexus RX330 with navigation? Any help would be appreciated.
Old Jan 4, 2011 | 07:48 AM
mandyfig's Avatar
mandyfig
The owner's manual states the procedure, check it out.
Old Jan 4, 2011 | 08:23 AM
Tomcio78's Avatar
Tomcio78
Thank you... found it... I knew how to sort of do it but totally forgot about the ODO/TRIP button on the side of the steering wheel.
Old Jan 4, 2011 | 08:25 AM
Rainbird's Avatar
Rainbird
Make sure the odometer is set to total miles not trip. With the key in the off position, push in and hold the odometer button (ODO). Turn the key to the on position without starting the car. Continue to hold in the odometer reset button until the maintenance required light goes off (about 20 seconds).
Old Jan 4, 2011 | 08:57 AM
mandyfig's Avatar
mandyfig
There you go. The many times I have done this, I still can not memorize this procedure. I do now.
Old Jan 4, 2011 | 12:02 PM
Jetstar's Avatar
Jetstar
Default Additional info.
If the procedure doesn't work, some models require that when you turn the key to the off position, you have to remove the key and re-insert it before turning it back on.
andy595
GX - 1st Gen (2003-2009)
Oct 26, 2011 09:42 AM
bigolow
Jun 23, 2011 07:04 PM
Rudy602
Nov 27, 2010 12:27 PM
amnstjohn
Dec 20, 2007 12:19 AM
wiredGS400
Jun 12, 2007 01:27 PM
