PRNDL back lighting
Have an 2004 RX330, Japan built. Recently, the back lighting on the gear shift went out. At night I can see what gear I am in the gauges, however, I cannot if I look down at the gear shift itself.
Have searched the forums to no avail. Does anyone have instructions or a schematic of that area which shows what needs to be taken apart to get to the bulb? Believe that is all that will be needed as I cannot find any bad fuses.
Input is greatly appreciated.
here's the instructions for taking the plate off...the bulb should be somewhere under there.
https://www.clublexus.com/forums/rx-...-04-07-rx.html
I knew how to get the trim cover off, sorry about not stating that. Just cannot locate or get to the bulb. Was thinking I needed to take off a side panel.
Guess I will need to go to the dealer and ask there. Will be in that area tomorrow anyway.
BinaryJay
May 7, 2011 08:40 PM
