front headlight issue
Old Jan 31, 2010 | 12:02 PM
Georgie's Avatar
Georgie
Default front headlight issue
Front driver side low beam headlight is out. I am assuming that the AFS warning light is the indication that the problem exists. Local garage mechanic told me it is not a $50.00 bulb but a $1000.00 wattage amplifer? If this is truely the issue, then why do the other front headlights work on the same side? I own a 2006 RX 330 with 48k miles. Please provide feedback. Thx
Old Jan 31, 2010 | 12:40 PM
arnieosp's Avatar
arnieosp
Read this:
https://www.clublexus.com/forums/rx-...-computer.html
and next time try "search" first.
Old Jan 31, 2010 | 04:21 PM
mandyfig's Avatar
mandyfig
You still have warranty, take it in.
Old Feb 2, 2010 | 07:09 AM
mmlex1987's Avatar
mmlex1987
Your emchanic is referring to the ballast, which powers up the low beam HID bulb. Doing a search as stated above will give you much information. Make sure you read through all before spending a whole bunch of money. Also, you should re-seal the headlamp assembly also desribed in the forums doing a search. Good luck.
Old Feb 2, 2010 | 08:40 AM
mandyfig's Avatar
mandyfig
WARRANTY.....still have it, do not sweat it, take it in.
Or is there something we are not aware of?
48K, means below 50K. Unless your service date was January 2004. Then warranty's out. In that case, more research is required.
I am fortunate not to have the HID. Based on what I have heard when they go out, a lot of $$.
Old Feb 2, 2010 | 02:18 PM
joako's Avatar
joako
I noticed heavy condensation inside a headlamp and within 2 months that low beam stopped working. I took it to the dealer and the entire headlamp was replaced and they washed the car. Upon pick up the other headlamp has condensation and it was replaced, they did not wash the car the 2nd time.
It was not a hassle at all besides the normally poor service the dealer provides (having to follow up on them if they ordered the part, did it arrive, etc.)
tbarrios
Sep 29, 2018 04:42 PM
Uzairlexus
Feb 24, 2014 08:32 PM
Leegs1
Jan 2, 2014 07:33 AM
prowler97
Hybrid Technology
Sep 27, 2012 11:43 AM
derekchiou
Sep 17, 2011 08:32 AM
