ATF drain?
Old Dec 10, 2009 | 04:10 PM
username:'s Avatar
username:
Default ATF drain?
Looking to drain/fill new ATF. I only found a DIY for the RX300 https://www.clublexus.com/forums/rx-...er-change.html. Is it the same for a 04 RX330 FWD?
Old Dec 11, 2009 | 08:02 AM
lexus114's Avatar
lexus114
Yep,but we have that stupid plastic under their to remove,that the rx300 doesnt have. Just makes the job a little longer. I forgot to mention,since yours is FWD,it will probably only take 3.5 quarts.
Old Dec 11, 2009 | 09:16 AM
mandyfig's Avatar
mandyfig
Yes, same as mentioned above. 3.5 sounds about right. The Owner's manual specifies the right amount.
Old Dec 11, 2009 | 11:57 AM
username:'s Avatar
username:
Ok thanks for the replys. Also, to fill, is it through the tranny dip stick?
What fluid do you guys recommend Toyota Type T-IV?
Old Dec 11, 2009 | 03:33 PM
davesmith's Avatar
davesmith
don't just drain and refill, FLUSH it with 12 QTS of ATF T-IV (TOYOTA PART # TO00279-000T4-01)
Old Dec 26, 2009 | 10:33 AM
johncdoyle's Avatar
johncdoyle
Yes, refill through the dipstick. Mine is AWD and it took 4 qts.
Old Dec 28, 2009 | 10:34 AM
mandyfig's Avatar
mandyfig
No flushing recommended. Drain and fill with T-IV. You can do it as much as you want. I do it every other oil change and my dipstick shows PINK fluid. Means GOOD and FRESH ATF.
jcjr
RX - 1st Gen (1999-2003)
13
Jun 29, 2013 05:34 PM
infinirx
Jan 3, 2012 06:09 AM
memGS300
Performance
29
Jul 24, 2009 02:48 PM
2MCHPSI
Jan 1, 2006 03:00 PM
autodriver
Maintenance
May 24, 2004 11:00 AM
