RX Ballast
Old Nov 10, 2009 | 09:09 PM
mmlex1987's Avatar
mmlex1987
Default RX Ballast
I am new to this website, which by the way I find to be very informative with alot of great information and help.
-I keep hearing to buy a part from a club lexus vendor? Where should I go for a ballast for my 04 RX 330? I hear ebay and find most to be used? Is that what is recommeneded?
-Also, regarding AFS. If my vehicle has rain sensing wipers and headlamp washers, as well as the headlamps go up/down and then level off, does that mean I have AFS? Thanks again...............
Old Nov 11, 2009 | 03:32 AM
kiwi's Avatar
kiwi
First, sounds like you have AFS to me.
Second, too bad about your headlight. i would make sure you buy a decent quality ballast, as you dont want to waste your money on a high ticket item.
consider yourself lucky, when i worked at acura, a guy with a TL had his bulb go, he needed a bulb, ballast and igniter, came to 1000 bucks.
Old Nov 11, 2009 | 03:56 AM
kitlz's Avatar
kitlz
No, I don't play soccer!
Mike, it sounds like you have AFS which was standard on the performance package (illuminated door sills, air suspension, 18" wheels). There is a button to turn AFS off under the steering wheel. I can't remember if auto leveling was unique to AFS or standard with HIDs.
I can't help you with the parts but the DIYers here will definitely give you some suggestions as to where to go. Good luck.
Old Nov 11, 2009 | 06:50 AM
lexus114's Avatar
lexus114
If you have HID`S you have AFS.
Old Nov 11, 2009 | 07:00 AM
kitlz's Avatar
kitlz
Really? I can't remember from six years ago when I picked up my 04.
Old Nov 11, 2009 | 07:12 AM
lexus114's Avatar
lexus114
yeah,it`s part of the HID option.Due to the brightness they want to try and not blind other drivers.
Old Nov 11, 2009 | 07:19 AM
kitlz's Avatar
kitlz
I tried to find it in the 2004 brochure/window sticker this morning but it wasn't clear. Thanks!
Old Nov 11, 2009 | 07:37 AM
lexus114's Avatar
lexus114
The leveling sensor is behind the r/r wheel (under the vehicle)
Old Nov 11, 2009 | 08:13 AM
mmlex1987's Avatar
mmlex1987
Will my vin number decifer whether or not I have AFS What exactly does AFS stand for? The reason I keep asking is because Ebay sellers are telling me I don't have AFS and if I buy a whole new asembly due to moisture reasons, it matters whether or not I have AFS.
Here's what I do know my 04 RX 330 has for options: 18" wheels, Nav, illuminated entry, rain sensing wipers, headlight washers, mark levinson sound....not sure about the air suspension, anyone know how to tell? Thanks,
Still need to know who anyone recommends to but a ballast from.
Old Nov 11, 2009 | 09:03 AM
kiwi's Avatar
kiwi
look to the right of the seat heater switch, there will be a switch for up and down if you have air ride, if not, there is nothing.
or look at your suspension, if you see a coil spring, no air ride.
Old Nov 11, 2009 | 09:55 AM
kitlz's Avatar
kitlz
And the control to turn off the air suspension is underneath the steering wheel a few inches away from the one to turn off AFS. I also have a button next to the gas door release to move the car up and down with a picture of a seat.
AFS = Adaptive front lighting system
http://www.denso.co.jp/motorshow/200...df/pdf13_e.pdf
Old Nov 11, 2009 | 10:28 AM
lexus114's Avatar
lexus114
We can turn off the AFS?
Old Nov 11, 2009 | 10:48 AM
lexus114's Avatar
lexus114
Well I just checked the online manual,and you can turn off the afs. I may have to try it,and see what the difference is.
tod071's Avatar
tod071
+1. Didn't know that either. Need to go check my buttons now.
Old Nov 11, 2009 | 11:49 AM
kitlz's Avatar
kitlz
I might be mistaken where the AFS button is. It might be by the gas door release. Can't remember now. All these stupid buttons everywhere, hard to keep track
