Problem after tire rotation???
Old Mar 3, 2008 | 07:50 PM
initiald15's Avatar
initiald15
Default Problem after tire rotation???
I just did a tire rotation today basically switch back tires to front and front tires to back. After that I notice when I am driving on the freeway... small aliagment problem and it makes some noise in the axel area. Does anyone ever experience the same or similar problem? Any idea?
THank you!
Old Mar 3, 2008 | 11:17 PM
arnieosp's Avatar
arnieosp
Aren't you supposed to rotate all 5 tires to ensure the even wear on all of them?
Old Mar 3, 2008 | 11:21 PM
Kaydee's Avatar
Kaydee
Hacked CL to become a Mod
5 of them????
check to see if the bolts are loose, i don't think tire rotation is supposed to do that sort of thing
Old Mar 4, 2008 | 09:27 AM
BrownRB's Avatar
BrownRB
Happened to me. Got the front's re-balanced and that fixed it.
Old Mar 4, 2008 | 10:14 AM
Lexmex's Avatar
Lexmex
Agree, with Kaydee, check to see if the bolts are tight, though what BrownRB said isn't out of the question on balancing.
When I do balancing and rotation (usually I do it at the same time unlike alignment), I always have an alignment done afterwards, and for AWD models, I make sure they use a Hunter alignment machine that can adjust the alignment for the rear as well. I used to get noise in the rear until I switched from the Bear to the Hunter machine.
Old Mar 4, 2008 | 10:18 AM
Gibster's Avatar
Gibster
The manual shows a 5 wheel rotation but most Lexus dealers will only rotate 4 (not the spare) unless you request it. Of course then there is an additional charge. Not quite up to Lexus standards if you ask me.
Old Mar 4, 2008 | 12:56 PM
ecount00's Avatar
ecount00
be sure and get it looked at asap tho. may be nothing, but may be unsafe if it's loose bolts.
Old Mar 4, 2008 | 04:37 PM
Grumpa72's Avatar
Grumpa72
I had similar issues BEFORE I did a tire rotation. Once I did the rotation, the noise and very slight pull went away. So, this tells me that one of my tires is worn unevenly. I have the original Michelins on my 05 with 38000 miles on them so it isn't out of line to expect one to wear oddly.
I would do a visual inspection of the tire, try a balance as suggested, and, if all else fails, rotate them back. How many miles do you have on the tires?
Old Mar 4, 2008 | 05:22 PM
ecount00's Avatar
ecount00
it's been said, check the bolts just to be sure. doesnt sound bad as this but you do not want this to be you.
https://www.clublexus.com/forums/sho...d.php?t=338583
Old Mar 5, 2008 | 03:02 AM
grouch's Avatar
grouch
I saw a TSB on tire rotation that said something to the effect that "after a tire rotation, test drive the veh. If it pulls to one side, reverse the front tires and test drive again".
Of course I can't find it now, but you might be able to call your dealership and talk to their technician.
lexus114
RX - 1st Gen (1999-2003)
25
Mar 30, 2015 08:25 AM
sallydrive
Jun 17, 2012 02:19 PM
2slixx
Mar 6, 2012 07:27 PM
oldcajun
Hybrid Technology
Oct 1, 2006 08:10 PM
newyorker
Wheels, Tires & Brakes Forum
Dec 13, 2002 06:20 PM
