I am going away for 6 weeks and I was wondering if there is something that I should do before i left. I have about 4 weeks before i leave so i wanted to know ahead of time.
at the moment i was going to:
- cover the car
- disconnect the battery
- oil change (synthetic) - already done
Strongly suggest u do not disconnect the battery if it is only for 6 weeks. I am away for 10 weeks a year & don't do that & never had a problem. I do use 100% synthetic oil & also cover the car even though it is in a garage.
There are tiny chargers out there, called float chargers, that will keep the battery topped off without boiling off the electrolyte. In the classsic car world, we have these chargers on our cars that might not get driven for months at a time. As I understand it, a standard charger isn't "smart" and will continue to add a small charge right up to the point of even baking your battery dry.
Here is a source (usual disclaimer - no interest in these products):
1. Battery Minder from Restoration Batter 513-574-4481
2. Battery Tender http://64.187.109.56/why_batterytend...6d5d0996dee9d5
3. Battery Butler 708-563-0400
They all claim to keep the battery fully charged without over charging. In addition, it is my understanding that the memory function of the radio and seats will drain our battery in 4-6 weeks. I remember reading that new Corvette owners were having dead batteries in their cars when they sat for long periods of time for this reason.
6 weeks is not a long time. If the battery is old or weak, then having it tended will be a good idea.
The only other ting I would add is to fill up your gas tank. You may want to inflate your tires to a higher than reccomended air pressure (do not exceed the marked maximum on the tires). If you want to go an extra mile, think about jacking all four corners, so that wheels barely touch the ground.
Your gas tank will have air above the fuel level. The air above is full of gas vapors and humid air. By filling up your gas tank, you are removing a large portion of moisture with real fuel. I am not a fan of additives .. other than what ever the petrol pump adds.
