bluetooth audio??
Old Jan 31, 2026 | 06:53 PM
tomr51's Avatar
tomr51
Default bluetooth audio??
on the 2nd gen rx350 you can use this, Bluetooth Audio Musik Adapter LEXUS IS ISF GS RX LS 300 350 400ht, to get bluetooth audio. the unit plugs into the cassette player unit and allows audio via the cassette. I also uses a y connector so all steering wheel functions etc are maintained. Is there a similar system for the gen 3 rx350 9 Cost is <$100)
Bluetooth Audio Musik Adapter LEXUS IS ISF GS RX LS 300 350 400h - Picture 1 of 1
Old Jan 31, 2026 | 08:14 PM
carguy75's Avatar
carguy75
No need for an adapter on a 3rd generation RX350 as it has Bluetooth audio playback from the factory.
Old Jan 31, 2026 | 09:50 PM
tomr51's Avatar
tomr51
not all models in australia
Old Jan 31, 2026 | 10:09 PM
dwoods801's Avatar
dwoods801
Is there an auxiliary jack hidden somewhere? If it didn’t come with Bluetooth from the factory then it probably came with a 3.5mm jack somewhere that u can use to plug into the audio system and get much better results than they the tape deck
Old Jan 31, 2026 | 11:55 PM
tomr51's Avatar
tomr51
yes it has the aux jack which is currently being used . disadvantage with an iphone is you cannot charge the phone at the same time .
Old Feb 1, 2026 | 05:28 AM
ChattanoogaPhil's Avatar
ChattanoogaPhil
Wife's 2010 RX has a 12-volt cigarette lighter/power outlet in the center console.
In my Tundra I use a Scosche BT/FM to stream from my iPhone to the radio. Works really well without wires dangling like other devices. It has charge ports too. Not as sophisticated as what is shown in the OP but it's quick and easy to use.
Old Feb 2, 2026 | 12:12 AM
tomr51's Avatar
tomr51
i own 2 gen 2 and 1 gen3 rx350 this post referred to the rx350 gen 3 so i do not understand it being moved to the gen 2 forum
Old Feb 2, 2026 | 06:28 AM
ChattanoogaPhil
Probably because your post started with: "on the 2nd gen rx350" It was only in the last few words of your post where you mentioned gen 3.
Old Feb 5, 2026 | 05:26 AM
highmile5's Avatar
highmile5
I bought a $8 stereo cassette adapter and a $18 bluetooth receiver that plugs into the cigarette lighter, works great when using bluetooth streaming from your phone.
Old Feb 7, 2026 | 05:48 PM
tomr51's Avatar
tomr51
you can use this adaptor allow playing music thru the aux port and at the same time charge your iphone form the 12v port
IPhone Jack to 3.5mm Splitter 2 in 1 Adapter to AUX Headphone Jack and Charger - Picture 1 of 15
Old Feb 8, 2026 | 07:28 AM
highmile5's Avatar
highmile5
gen2 has no aux port accessible.
Old Feb 8, 2026 | 01:59 PM
tomr51's Avatar
tomr51
correct the post was moved from gen 3nto gen 2 you can use a cassettes adaptor in gen 2 to give charging and audio with the above device
tomr51
Jan 31, 2026 06:57 PM
shkl
RX - 3rd Gen (2010-2015)
Apr 17, 2017 07:46 AM
hieu
Sep 10, 2011 10:23 AM
