View Poll Results: Which Struts Wore Out First?
Front
50.00%
Rear
14.29%
Front & Rear at the same time
14.29%
Still on my originals
21.43%
Voters: 14. You may not vote on this poll
Which Struts Did You Replace First, Front or Rear?
Old Feb 21, 2025 | 10:00 AM
spinellib's Avatar
spinellib
Default Which Struts Did You Replace First, Front or Rear?
*See POLL Above!*
Front?
Rear?
Still on Originals?
Don't know/remember?
Replaced all at the same time?
Also: mention if you Tow, or your is loaded with crap because you're a hoarder. Or if you drive alone, or always cart around your entire family of 5 everywhere you go.
Reason I ask is because I think my Rears are going (75K miles) but I thought my Fronts would go first. I don't tow, and I'm usually the only "Load" in the car, plus maybe a 75lb electric scooter.
Old Feb 21, 2025 | 01:17 PM
Leeper's Avatar
Leeper
Originally Posted by spinellib
*See POLL Above!*
Front?
Rear?
Still on Originals?
I did exactly what you shouldn't, I did one rear one front will do the other two shortly. RX330 170k miles those two were most leaking. All said the car is very front heavy biased so they're likely to go out first.
Old Feb 21, 2025 | 02:57 PM
MattRX's Avatar
MattRX
I did all four of mine at once on my RX. I've done pairs before on friend's cars and it always doesn't feel right having one side feel fresh, really highlights how worn the other axle is. I'm always extremely picky about my cars, especially suspension. This RX has never towed, and I'm usually the only person in the car. However, I do a lot of parts runs or dump runs with this car, sometimes in excess of 1000 lbs. Having new suspension and Eibach springs on there, it is remarkable how little it sags and how it doesn't bottom out despite that weight.
Old Feb 21, 2025 | 04:39 PM
spinellib's Avatar
spinellib
1/2 Ton?!?! That's like classic F-150 payload.
For our cars, they're so old, it doesn't matter, Just fix what needs it the most & Go.
(I wish I could do that -- I'll admit I'm too fussy and obsessive.)
Old Feb 21, 2025 | 05:01 PM
MattRX's Avatar
MattRX
I still can't believe how well it handles all that weight. I take it easy to not unsettle what's inside, but the car itself felt fine apart from the transmission wanting to shift a little later to save it from the load. You'd think with how stiff those springs are, it would ride rough when empty, but not really! It feels firm like you'd expect out of a BMW or so, but not overly harsh at all. It still rides better than our '14 RX which would have been sagging like crazy!
https://www.clublexus.com/forums/rx-...g-payload.html
Old Feb 22, 2025 | 11:55 AM
Margate330's Avatar
Margate330
I replaced my front struts first.
Only reason is I figured that I would feel a difference of improvement easier on the front.
Old Mar 5, 2025 | 08:46 AM
Felix's Avatar
Felix
I replaced the front struts w/ KYB's (using the oem springs) as a front one was seeping & I figured it'd help w/ a little w/ anti brake diving. I surprised that Toyota didn't include a electronic brake force distrubution. Looking at the little link on the right rear control arm & finding its for the afs height adjustment depending on the load of the vehicle. Adding a gen2 Highlander brake package did help somewhat w/ anti dive, thanx to the bigger diameter rear rotors. I could add a Baer brake adjustable brake proportioning block as I've done on a couple of Mustangs & a Camaro yrs ago, but I didn't want to mess w/ Toyota anti lock as this brake system is totally diffeerent then what I'm use to.
Old Mar 5, 2025 | 10:14 AM
MattRX's Avatar
MattRX
The ABS module / ECU controls the brake distribution on these (EBD). I always wonder what people who track their Toyotas do or if they just leave it alone.
Old Mar 5, 2025 | 03:04 PM
Felix's Avatar
Felix
The system sure doesn't do anything 'bout brake dive thou.....
Old Mar 5, 2025 | 06:29 PM
MattRX's Avatar
MattRX
Probably sends more power up front than anything to be more conservative, I can see Toyota pulling that off on their cars. The brake dive on mine is really good though, not much dive under braking and not a lot of squat when flooring it either. It's a lot better than any stock Camry/ES350 I've tried. The Eibach springs had a lot to do with that, but I'm sure some shocks with some proper anti-dive built in would work a treat (or swapping to coilovers which is on the list).
Old Mar 6, 2025 | 10:29 PM
spinellib's Avatar
spinellib
..and Matt
Did you replace the stabilizer bar links, too? Or the mounts and/or bearings?
Old Mar 7, 2025 | 04:04 AM
MattRX's Avatar
MattRX
I did all four links and the front and rear sway bar bushings too. I swapped the rear mounts and kept the stock front mounts and put in new OEM bearings into them.
The aftermarket front TRW mounts I got were so crap that the studs snapped when I went to go torque them. For some reason no one can make a good aftermarket front strut mount for these cars.
Old Mar 7, 2025 | 06:36 AM
Margate330's Avatar
Margate330
..and Matt
I recommed only using oem strut links unless you want to do the job again in a year. Lol
My links were noisy over bumps so I bought new aftermarket links from the local auto part store.
Absolute junk.
Noise started again after a couple of months and by 6 months, they were more noisy than the original ones I replaced, JUNK. Haha
Oh, and for a bonus, the allen screw is not the oem size, just for added fun. Lol
So I replaced them again with oem and it's been a few years and all good!
Everyone don't go cheap on the sway bar links. 😃
Old Mar 9, 2025 | 10:26 PM
Felix's Avatar
Felix
I replace the rear end links when I did the rear brakes last yr, Just need to do the front ones next....I've also hauled 18 boxes of Luxury vinyl flooring, when I did the kitchen/dining room, which lowered it, just needed the front the same height......LOL
Old Mar 10, 2025 | 05:33 AM
fabchef's Avatar
fabchef
I ended up changing all 4 corners (long story) and went with fcs quick struts all around. I've also changed all 4 corner, sway bar links as well (mevotec supreme). So far so good. I may have to change one of the front, strut mount top plates. Other than that it rides okay...much stiffer then stock. The rest of suspension is stock.
madchy
Apr 24, 2024 03:35 PM
Soniro
Mar 21, 2024 01:54 PM
Corn99Devi
Apr 15, 2023 07:14 AM
Kurtsrx
Feb 15, 2023 01:20 PM
