Rear Struts Access LC500
Old Dec 12, 2023 | 03:57 PM
Soniro's Avatar
Soniro
7th Gear
Default Rear Struts Access LC500
Does anyone have instructions on easiest way to access the top of the rear struts on an LC?
Thanks
Old Dec 15, 2023 | 08:07 AM
iVector's Avatar
iVector
9th Gear
Take out the rear back seats. The lower half comes out by just pulling up. Then there should be 4 bolts holding up the backrest, remove those, and then 1 on each side behind the backrest finishing trim (Right behind where your neck would sit)
After all the lower and upper bolts are removed, pull the backrest out. There should then be 2 finishing plates for each strut tower on each side. Remove all the bolts and you should be able to access the top of the strut tower on each side.
Hope that helps, and if you have any questions, don't hesitate to ask!
Old Dec 15, 2023 | 10:57 AM
Soniro's Avatar
Soniro
7th Gear
Thanks for the reply. Started tearing out the seats and figured it out
Old Mar 21, 2024 | 12:56 PM
antidentit's Avatar
antidentit
I'm curious @Soniro if you were asking about accessing the rear stuts to solve a squeaking/rattling sound coming from that area, and if so, were you able to fix it?
Old Mar 21, 2024 | 01:54 PM
Soniro's Avatar
Soniro
7th Gear
Hi no I was installing RSR Coilovers not fixing a squeak.
Kurtsrx
Feb 15, 2023 01:20 PM
radhead25
RX - 1st Gen (1999-2003)
Dec 28, 2005 03:28 PM
tantheman
Nov 26, 2003 11:16 AM
